I’m trying to add a Sonoff Zbbridge Gateway but it’s not working.
Everything is flashed to the latest version.
The Gateway works fine with mqtt.
Tasmota-zigbee 9.4.0.3, ezsp radio 6.7.9
HomeAssistant Docker core-2021.5.1 (home-assistant:db7f14025cea)
Debug Log:
2021-05-08 17:51:29 DEBUG (MainThread) [bellows.ezsp] Resetting EZSP
2021-05-08 17:51:30 DEBUG (MainThread) [bellows.ezsp.protocol] Send command version: (4,)
2021-05-08 17:51:31 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 0 (version) received: b'08029067'
2021-05-08 17:51:31 DEBUG (MainThread) [bellows.ezsp] Switching to EZSP protocol version 8
2021-05-08 17:51:31 DEBUG (MainThread) [bellows.ezsp.protocol] Send command version: (8,)
2021-05-08 17:51:31 DEBUG (MainThread) [bellows.ezsp] EZSP Stack Type: 2, Stack Version: 6790, Protocol version: 8
2021-05-08 17:51:31 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD: 34>, 2)
2021-05-08 17:51:31 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 83 (setConfigurationValue) received: b'00'
2021-05-08 17:51:31 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_SUPPORTED_NETWORKS: 45>, 1)
2021-05-08 17:51:32 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 83 (setConfigurationValue) received: b'00'
2021-05-08 17:51:32 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT: 19>, 8)
2021-05-08 17:51:32 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_STACK_PROFILE: 12>, 2)
2021-05-08 17:51:32 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_MULTICAST_TABLE_SIZE: 6>, 16)
2021-05-08 17:51:33 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 83 (setConfigurationValue) received: b'00'
2021-05-08 17:51:33 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_TC_REJOINS_USING_WELL_KNOWN_KEY_TIMEOUT_S: 56>, 90)
2021-05-08 17:51:33 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS: 42>, <EmberZdoConfigurationFlags.APP_HANDLES_UNSUPPORTED_ZDO_REQUESTS|APP_RECEIVES_SUPPORTED_ZDO_REQUESTS: 3>)
2021-05-08 17:51:33 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_ADDRESS_TABLE_SIZE: 5>, 16)
2021-05-08 17:51:34 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 83 (setConfigurationValue) received: b'00'
2021-05-08 17:51:34 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_SOURCE_ROUTE_TABLE_SIZE: 26>, 16)
2021-05-08 17:51:34 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_SECURITY_LEVEL: 13>, 5)
2021-05-08 17:51:35 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 83 (setConfigurationValue) received: b'00'
2021-05-08 17:51:35 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE: 25>, 2)
2021-05-08 17:51:35 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT: 18>, 7680)
2021-05-08 17:51:35 DEBUG (MainThread) [bellows.ezsp.protocol] Send command setConfigurationValue: (<EzspConfigId.CONFIG_PACKET_BUFFER_COUNT: 1>, 255)
2021-05-08 17:51:35 DEBUG (MainThread) [bellows.ezsp.protocol] Send command getConfigurationValue: (<EzspConfigId.CONFIG_APS_UNICAST_MESSAGE_COUNT: 3>,)
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 82 (getConfigurationValue) received: b'000a00'
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.zigbee.application] APS_UNICAST_MESSAGE_COUNT is set to 10
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp.protocol] Send command addEndpoint: (1, 260, 48879, 0, 0, 1, [], [1280])
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 2 (addEndpoint) received: b'00'
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.zigbee.application] Ezsp adding endpoint: [<EzspStatus.SUCCESS: 0>]
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp] getting MFG_STRING token
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp.protocol] Send command getMfgToken: (<EzspMfgTokenId.MFG_STRING: 1>,)
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 11 (getMfgToken) received: b'10ffffffffffffffffffffffffffffffff'
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp] getting MFG_BOARD_NAME token
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp.protocol] Send command getMfgToken: (<EzspMfgTokenId.MFG_BOARD_NAME: 2>,)
2021-05-08 17:51:36 DEBUG (MainThread) [bellows.ezsp.protocol] Send command getValue: (<EzspValueId.VALUE_VERSION_INFO: 17>,)
2021-05-08 17:51:37 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 170 (getValue) received: b'0007950106070900aa'
2021-05-08 17:51:37 DEBUG (MainThread) [bellows.ezsp.protocol] Error processing 18 response. getValue command timed out?
