I have here a Zigbee emergency button which does register and show it’s battery left, but does not show when it is being pressed. Anyone has experience with this button? It is available through AliExpress.
This is the log:
[0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_req: [60, <Bool.false: 0>]
Device 0xe6f7 (84:71:27:ff:fe:0d:15:6c) joined the network
Skip initialization for existing device 84:71:27:ff:fe:0d:15:6c
[0xe6f7:zdo] ZDO request ZDOCmd.Device_annce: [0xE6F7, 84:71:27:ff:fe:0d:15:6c, 128]
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=7 command_id=Command.Read_Attributes_rsp>
[0xE6F7:1:0x0001]: finished channel configuration
[0xE6F7:1:0x0500]: 'async_initialize' stage succeeded
[0xE6F7:1:0x0001]: 'async_initialize' stage succeeded
[0xE6F7:1:0x0000]: 'async_initialize' stage succeeded
[0xE6F7:1:0x0019]: 'async_initialize' stage succeeded
[0xE6F7](TS0218): power source: Battery or Unknown
[0xE6F7](TS0218): completed initialization
Device 0xe6f7 (84:71:27:ff:fe:0d:15:6c) left the network
[0xe6f7:1:0x0500] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=6 command_id=1>
[0xe6f7:1:0x0500] ZCL request 0x0001: [<ZoneType.Key_Fob: 277>, 4098]
[0xe6f7:1:0x0500] No handler for cluster command 1
[0xE6F7:1:0x0500]: Enroll requested
[0xe6f7] Extending timeout for 0x0d request
[0xe6f7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=7 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0000] ZCL request 0x000a: [[Attribute(attrid=1, value=<TypeValue type=uint8_t, value=66>)]]
[0xe6f7:1:0x0000] Attribute report received: app_version=66
Error handling '_save_attribute' event with (84:71:27:ff:fe:0d:15:6c, 1, 0, 1, 66) params: FOREIGN KEY constraint failed
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=8 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0001] ZCL request 0x000a: [[Attribute(attrid=32, value=<TypeValue type=uint8_t, value=30>), Attribute(attrid=33, value=<TypeValue type=uint8_t, value=200>)]]
[0xe6f7:1:0x0001] Attribute report received: battery_voltage=30, battery_percentage_remaining=200
Error handling '_save_attribute' event with (84:71:27:ff:fe:0d:15:6c, 1, 1, 32, 30) params: FOREIGN KEY constraint failed
Error handling '_save_attribute' event with (84:71:27:ff:fe:0d:15:6c, 1, 1, 33, 200) params: FOREIGN KEY constraint failed
[0xe6f7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=9 command_id=Command.Report_Attributes>
Duplicate 9 TSN
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=10 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=11 command_id=2>
[0xe6f7:1:0x0501] ZCL request 0x0002: []
[0xe6f7:1:0x0501] No handler for cluster command 2
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=12 command_id=2>
[0xe6f7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=13 command_id=Command.Report_Attributes>
Duplicate 13 TSN
[0xe6f7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=14 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=15 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=16 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=17 command_id=2>
Sending 'zdo_leave_req' failed:
[0xe6f7] Requesting 'Node Descriptor'
Tries remaining: 2
[0xe6f7] Extending timeout for 0x14 request
Received frame on uninitialized device 84:71:27:ff:fe:0d:15:6c (Status.NEW) for endpoint: 1
[0xe6f7] Received ZCL while uninitialized on endpoint id 1, cluster 0x0500 id, hdr: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=19 command_id=1>, payload: b'\x15\x01\x02\x10'
[0xe6f7] Received ZCL while uninitialized on endpoint id 1, cluster 0x0501 id, hdr: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=20 command_id=2>, payload: b''
[0xe6f7] Node Descriptor: NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0)
[0xe6f7] Discovering endpoints
Tries remaining: 3
[0xe6f7] Extending timeout for 0x16 request
Received frame on uninitialized device 84:71:27:ff:fe:0d:15:6c (Status.NEW) for endpoint: 255
[0xe6f7] Received ZCL while uninitialized on endpoint id 1, cluster 0x0000 id, hdr: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=21 command_id=Command.Report_Attributes>, payload: b'\x01\x00 B'
[0xe6f7] Uninitialized device command 'Command.Report_Attributes' args: [[Attribute(attrid=1, value=<TypeValue type=uint8_t, value=66>)]]
[0xe6f7] Received ZCL while uninitialized on endpoint id 1, cluster 0x0001 id, hdr: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=22 command_id=Command.Report_Attributes>, payload: b' \x00 \x1e!\x00 \xc8'
[0xe6f7] Uninitialized device command 'Command.Report_Attributes' args: [[Attribute(attrid=32, value=<TypeValue type=uint8_t, value=30>), Attribute(attrid=33, value=<TypeValue type=uint8_t, value=200>)]]
[0xe6f7] Discovered endpoints: [1]
[0xe6f7:1] Discovering endpoint information
Tries remaining: 3
[0xe6f7] Extending timeout for 0x18 request
Received frame on uninitialized device 84:71:27:ff:fe:0d:15:6c endpoint 1 for cluster: 1281
[0xe6f7:1] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=1025, device_version=0, input_clusters=[0, 1, 3, 1280], output_clusters=[25, 1281])
[0xe6f7] Extending timeout for 0x1a request
[0xe6f7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=26 command_id=Command.Read_Attributes_rsp>
[0xe6f7:1] Manufacturer: _TYZB01_trqoesc6
[0xe6f7:1] Model: TS0218
Checking quirks for _TYZB01_trqoesc6 TS0218 (84:71:27:ff:fe:0d:15:6c)
Considering <class 'zhaquirks.xbee.xbee_io.XBeeSensor'>
Fail because endpoint list mismatch: {232, 230} {1}
Considering <class 'zhaquirks.xbee.xbee3_io.XBee3Sensor'>
Considering <class 'zhaquirks.smartthings.tag_v4.SmartThingsTagV4'>
Fail because device_type mismatch on at least one endpoint
Considering <class 'zhaquirks.smartthings.multi.SmartthingsMultiPurposeSensor'>
Considering <class 'zhaquirks.philips.rwl021.PhilipsRWL021'>
Fail because endpoint list mismatch: {1, 2} {1}
Considering <class 'zhaquirks.philips.rwl020.PhilipsRWL020'>
Considering <class 'zhaquirks.philips.rom001.PhilipsROM001'>
Considering <class 'zhaquirks.netvox.z308e3ed.Z308E3ED'>
Considering <class 'zhaquirks.gledopto.soposhgu10.SoposhGU10'>
Fail because endpoint list mismatch: {11, 13} {1}
Considering <class 'bellows.zigbee.application.EZSPCoordinator'>
device - 0xE6F7:84:71:27:ff:fe:0d:15:6c entering async_device_initialized - is_new_join: True
device - 0xE6F7:84:71:27:ff:fe:0d:15:6c has joined the ZHA zigbee network
[0xE6F7](TS0218): started configuration
[0xE6F7:ZDO](TS0218): 'async_configure' stage succeeded
[0xe6f7] Extending timeout for 0x1c request
[0xe6f7] Extending timeout for 0x1e request
[0xe6f7] Extending timeout for 0x20 request
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=24 command_id=2>
[0xE6F7:1:0x0001]: bound 'power' cluster: Status.SUCCESS
[0xe6f7] Extending timeout for 0x22 request
[0xE6F7:1:0x0000]: bound 'basic' cluster: Status.SUCCESS
[0xE6F7:1:0x0000]: finished channel configuration
[0xe6f7] Extending timeout for 0x24 request
[0xe6f7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=25 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=26 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=34 command_id=Command.Default_Response>
[0xE6F7:1:0x0001]: reporting 'battery_voltage' attr on 'power' cluster: 3600/10800/1: Result: '[6, <Status.UNSUP_GENERAL_COMMAND: 130>]'
[0xe6f7] Extending timeout for 0x28 request
[0xE6F7:1:0x0019]: bound 'ota' cluster: Status.SUCCESS
[0xE6F7:1:0x0019]: finished channel configuration
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=40 command_id=Command.Default_Response>
[0xE6F7:1:0x0001]: reporting 'battery_percentage_remaining' attr on 'power' cluster: 3600/10800/1: Result: '[6, <Status.UNSUP_GENERAL_COMMAND: 130>]'
[0xe6f7:1:0x0000] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=27 command_id=Command.Report_Attributes>
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=28 command_id=Command.Report_Attributes>
Duplicate 28 TSN
[0xe6f7:1:0x0500] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=28 command_id=Command.Read_Attributes_rsp>
[0xE6F7:1:0x0500]: started IASZoneChannel configuration
[0xe6f7] Extending timeout for 0x2b request
[0xe6f7:1:0x0500] ZCL request 0x0001: [[ReadAttributeRecord(attrid=1, status=<Status.SUCCESS: 0>, value=<TypeValue type=enum16, value=enum16.undefined_0x0115>)]]
[0xE6F7:1:0x0500]: bound 'ias_zone' cluster: Status.TABLE_FULL
[0xe6f7] Extending timeout for 0x2d request
[0xe6f7:1:0x0500] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=45 command_id=Command.Write_Attributes_rsp>
[0xE6F7:1:0x0500]: wrote cie_addr: 80:4b:50:ff:fe:0a:d2:32 to 'ias_zone' cluster: [WriteAttributesStatusRecord(status=<Status.SUCCESS: 0>)]
[0xE6F7:1:0x0500]: Sending pro-active IAS enroll response
[0xE6F7:1:0x0500]: finished IASZoneChannel configuration
[0xe6f7] Extending timeout for 0x2f request
[0xE6F7:1:0x0500]: 'async_configure' stage succeeded
[0xE6F7:1:0x0001]: 'async_configure' stage succeeded
[0xE6F7:1:0x0000]: 'async_configure' stage succeeded
[0xE6F7:1:0x0019]: 'async_configure' stage succeeded
[0xE6F7](TS0218): completed configuration
[0xE6F7](TS0218): stored in registry: ZhaDeviceEntry(name='_TYZB01_trqoesc6 TS0218', ieee='84:71:27:ff:fe:0d:15:6c', last_seen=1615491551.0845764)
[0xe6f7] Extending timeout for 0x31 request
[0xe6f7:1:0x0500] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=29 command_id=1>
[0xe6f7] Extending timeout for 0x33 request
[0xe6f7:1:0x0003] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=49 command_id=Command.Default_Response>
[0xE6F7:1:0x0003]: executed 'trigger_effect' command with args: '(2, 0)' kwargs: '{}' result: [64, <Status.UNSUP_CLUSTER_COMMAND: 129>]
[0xE6F7](TS0218): started initialization
[0xE6F7:ZDO](TS0218): 'async_initialize' stage succeeded
[0xE6F7:1:0x0500]: initializing channel: from_cache: False
[0xe6f7] Extending timeout for 0x35 request
[0xE6F7:1:0x0001]: initializing channel: from_cache: False
[0xe6f7] Extending timeout for 0x37 request
[0xE6F7:1:0x0000]: initializing channel: from_cache: False
[0xE6F7:1:0x0019]: initializing channel: from_cache: False
[0xe6f7:1:0x0500] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=53 command_id=Command.Read_Attributes_rsp>
[0xE6F7:1:0x0500]: finished channel configuration
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=55 command_id=Command.Read_Attributes_rsp>
[0xe6f7] Extending timeout for 0x39 request
[0xe6f7:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=57 command_id=Command.Read_Attributes_rsp>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=30 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=31 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=32 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=33 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=34 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=35 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=36 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=37 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=38 command_id=2>
[0x60d8:1:0x0405] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=89 command_id=Command.Report_Attributes>
[0x60d8:1:0x0405] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint16_t, value=4046>)]]
[0x60d8:1:0x0405] Attribute report received: measured_value=4046
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=39 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=40 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=41 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=42 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=44 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=43 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=45 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=46 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=47 command_id=2>
[0xe6f7:1:0x0501] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=48 command_id=2>
[0x60d8:1:0x0405] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=90 command_id=Command.Report_Attributes>
[0x60d8:1:0x0405] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=uint16_t, value=4147>)]]
[0x60d8:1:0x0405] Attribute report received: measured_value=4147
Thanks in advance,
with friendly regards,
Gunther.
