I’m having a problem with a three-way switch that recognized only one, I deleted the device, put it back in pairing mode, and now it is no longer synchronizing with the Zigbee bridge
It seems like every device that I delete I can’t pair again with the zigbee bridge
Logs
[0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_req: [60, <Bool.false: 0>]
Device 0x61f5 (00:15:8d:00:04:77:4e:89) joined the network
[0x61f5] Requesting ‘Node Descriptor’
Tries remaining: 2
[0x61f5] Extending timeout for 0x5d request
Skip initialization for existing device 00:15:8d:00:04:77:4e:89
[0x61f5] Delivery error for seq # 0x5d, on endpoint id 0 cluster 0x0002: message send failure
Tries remaining: 1
[0x61f5] Extending timeout for 0x5f request
[0xc161:11:0x0019] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=200 command_id=1>
[0xc161:11:0x0019] ZCL request 0x0001: [0, 4478, 0, 1, None]
[0xc161:11:0x0019] OTA query_next_image handler for ‘FeiBit FNB56-ZSW01LX2.0’: field_control=0, manufacture_id=4478, image_type=0, current_file_version=1, hardware_version=None
[0xc161:11:0x0019] No OTA image is available
[0x4eaa:1:0x0019] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=112 command_id=1>
[0x4eaa:1:0x0019] ZCL request 0x0001: [0, 4478, 0, 1, None]
[0x4eaa:1:0x0019] OTA query_next_image handler for ‘FeiBit FNB56-ZSW03LX2.0’: field_control=0, manufacture_id=4478, image_type=0, current_file_version=1, hardware_version=None
[0x4eaa:1:0x0019] No OTA image is available
[0x61f5] Delivery error for seq # 0x5f, on endpoint id 0 cluster 0x0002: message send failure
[0x61f5] Requesting Node Descriptor failed
[0x61f5] Discovering endpoints
Tries remaining: 3
[0x61f5] Extending timeout for 0x63 request
[0x61f5] Delivery error for seq # 0x63, on endpoint id 0 cluster 0x0005: message send failure
Tries remaining: 2
[0x61f5] Extending timeout for 0x65 request
[0x61f5] Delivery error for seq # 0x65, on endpoint id 0 cluster 0x0005: message send failure
Tries remaining: 1
[0x61f5] Extending timeout for 0x67 request
[0x61f5] Delivery error for seq # 0x67, on endpoint id 0 cluster 0x0005: message send failure
Failed ZDO request during device initialization
[0xc161:11:0x0019] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=6 command_id=1>
[0x4eaa:1:0x0019] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=174 command_id=1>
