Got the Quirky+GE Tapt Switch working as a dumb on/off switch. Works great, but they have a lot of clusters & properties which are out of the 0-65535 range which makes it impossible to send commands to operate it as a keypad.
Now working again in 0.56.1
I updated to 0.56 last night and all of my Visonic MCT-340 E sensors are working. Both as binary sensors as well as, what appears to be, accurate temperature readings.
Iām eagerly awaiting support for the Bosch motion sensors.
Once the Bosch sensors are supported Iāll be able to ditch my Vera. Waiting patiently
Anyone able to get a TRĆ DFRI motion sensor paired and working? I canāt get it to connect, though zha seems to know itās trying as there are errors in the logs.
Did you ever get your RGB bulbs working again?
No, but I havenāt been able to upgrade past 0.55.2 because of this bug, which has been open for three weeks with no developer input, unfortunately.
@wixoff, Iām trying to debug this and think Iāve figured out the problem; can you check out my posts on your issue on GitHub?
For anyone reading this with the same problem as @wixoff, please check the GitHub issue. We were able to solve his problem, check the issue for a solution. Interested in hearing of anyone else with this problem.
Can someone with a Lutron connected Bulb Remote give me the output of bellows devices
? Interested to see how the output compares with the Hue Remote.
I tried the Connected Bulb Remote quite some time ago (#22 in this thread) and it wouldnāt even pair correctly, much less function. I can try again if you think that would be helpful, but if I recall correctly I had to nuke and re-do zigbee.db after I tried.
Well donāt blow up your config just for me. Iām just being lazy and not wanting to buy one. With @rcloran being away for the last little bit itās got me thinking about how to move the zha project forward in his absence, I was thinking I would take a look at remotes (namely the Hue Remote and the Lutron).
Well, itās a handy remote to have around even if itās not supported, because you can use it to reset bulbs easily!
I managed to successfully get the Lutron Remote to pair, shows up in the Zigbee database and everything, but doesnāt show in the HASS interface.
I can send you my Zigbee database, there wasenāt really much logged to syslog when I paired the remote just a generic āhas joined the networkā success message. I also donāt see anything logged when I press the buttons on the remote.
Let me know if thereās a debug log I can enable, would love to get these remotes working with HASS!
Has anyone figured out how to unpair a Zibee device from HA?
The only way Iāve found is to:
- stop HASS
- download the zigbee database file to my PC
- open it in an SQLite editor and remove all references to the deleted device
- re-upload the modified zigbee database
- restart HASS.
After all that, I reset the device to factory defaults.
If anyone has a better solution though Iām all ears cuz this way is a total pain!
Awesome that is a cool what off doing it.
Nope, thatās exactly what I do. I donāt know of any better approach.
anyone having issues with ZHA on the HUSBZB-1 device? I find I have to restart hass once a day to gain control of my zigbee devices again.
Nope. Thatās probably the thing I have the least problems with.
hmm I wonder where to even begin researching this issue.
