I have this code in my config that makes a small slider to control the volume of one of my amp outputs (didn’t post the other 5) but it is not enough to integrate with a Zigbee button. Everything works except the volume for the amp.
input_number:
av_vol1:
initial: 14
min: 1
max: 38
step: 1
av_vol2:
initial: 14
min: 1
max: 38
step: 1
shell_command:
set_vol_to_slider1: >-
bash -c 'echo -ne "<11VO{{'%02d'% states('input_number.av_vol1')|int }}\r\n" | nc 192.168.2.156 8080'
set_vol_to_slider2: >-
bash -c 'echo -ne "<12VO{{'%02d'% states('input_number.av_vol2')|int }}\r\n" | nc 192.168.2.156 8080'
Is there something I can add to the config to make the entities I need? I’ve made switches for the speakers to turn them off and on, which work with the remote.
Thank you
