Since this morning my ZHA fails. I’m running the latest incarnation of HA.
Running HA in a VM on Unraid. In the past I had some issues with passing through the Deconz USB Stick, but that does not seem to be the problem at this moment.
I googled the error message about the channel, cannot find anything related.
Anyone?
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:172
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 11:26:52 (3 occurrences)
Last logged: 11:27:00
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 144, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 125, in startup
await self.initialize(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 110, in initialize
await self.permit(0)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 929, in permit
await zigpy.zdo.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 518, in broadcast
return await app.broadcast(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 744, in broadcast
await self.send_packet(
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 419, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver packet: <TXStatus.MAC_CHANNEL_ACCESS_FAILURE: 225>
For future reference for other Conbee Zigbee stick users:
And also this problem turns out to be interference related. After moving my USB stick (already on an extension cord) to another random location it works again.
They should really fix this in in hardware, this causes insane amounts of random errors at random intervals.
What do you mean by another random location? You moved the conbee stick to another area in the room? How long is your extension cable?
I have a similar issue I think.
Source: /usr/src/homeassistant/homeassistant/runner.py:96
First occurred: 15:52:32 (1 occurrences)
Last logged: 15:52:32
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.10/site-packages/zigpy/zcl/__init__.py", line 324, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.10/site-packages/zigpy/endpoint.py", line 237, in request
return await self.device.request(
File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 297, in request
await self._application.request(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 654, in request
zigpy.exceptions.DeliveryError: Failed to deliver packet: <TXStatus.APS_NO_ACK: 167>
Holy crap i just spent the other night scratching my head while setting up a new rpi4 that was to use my old conbee2 and ive tried everything. Reflashing, upgrading, downgrading, reseting adapter on another machine, installing deconz (looked normal btw), reinstalling deconz and so on.
And i read this comment. and looked at the conbee2 that lies between my wireless keyboard, wireless mouse, next to my phone and my bluetooth adapter…
Took the conbee and threw it to the other side of the table and it worked!
THANK YOU!!! I moved my sd card today from a rp4 2gb to a rp4 4gb and half of my zigbee network wasnt working anymore. I’ve put the conbee2 dongle into the USB 3.0 because: why not? Now I know why not. After switching from “blue to grey” all is working again.
Thank you so much!
God dammit, everything has worked three years great and today all zigbees stopped working. After all trying, checking rebooting ex. But now i feel so dumb because just taking conbee out and putting back in + reboot helped…
I had a simular issue nut I already had the Conbee stick on an extention cord (1.5m) but I got the same error. Turned out I had to move the MiniPC not to be just beside the Wifi router.
All works again.
I had this error too. It was very weird because only Zigbee plugs were affected. Door sensors that were farther away still worked perfectly well.
In my case, the extension cable was lying under an external hard drive.
This happened to me too. I added an external USB SSD for my data storage and after this the ZHA would not work. Tried rebooting multiple times… No go. Found this thread and THANKS A LOT! After adding an extension cord to my Conbee stick everything seems to be working fine.
I had trouble connecting Aqara sensors to my ConBee II stick due to EMC (electromagnetic compatibility) issues. While my Zigbee network was stable during normal use, I consistently ran into problems when trying to pair new devices. Given I’m a stingy guy and could not wait for Monday to buy a USB extension cord, I found the following temporary solution to be surprisingly effective and satisfactory
I placed a strip of aluminum foil between my SSD (connected via USB 3.0) and the ConBee II (on USB 2.0) on my Raspberry Pi 4. That was enough to mitigate the EMI just enough to allow successful pairing.
I had a tough time pairing my Aqara sensors with the ConBee II stick—turns out it was an EMC issue. While the network held up fine otherwise, adding new devices was a nightmare. As a quick fix (because I couldn’t wait for a USB extension), repositioning the stick helped a lot! On a side note, I also started using a neat widget that shows *today’s Islamic date* right on my home screen—perfect for keeping track of important days without digging through apps!
