I’m sure I ran into something several ppl. faced with… after trying to fix some Sonoff related Zigbee error, my Sonoff dongle / Z2m is dead. I hope someone can suggest some easy solution and I don’t have to reset, re-pair all my devices (some sonoff minis behind dumb switches, so it would take days…)
I had some issue with zblmini and I’ve seen strange errors in the log, so I started searching for solutions. I’ve read about this ‘ember’ thing and changed the adapter to ember, z2m won’t start. Then I continued reading and found I have to upgrade the firmware too. First I upgraded to 7.3.x (w/o problem), then I found only 7.4.x would work. But now, it is not working with neither ezsp or ember and I always have messages like this in the log
[2024-07-21 11:32:15] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230324172249-if00 adapter: ezsp
[2024-07-21 11:32:15] debug: zh:ezsp:driv: EZSP could not connect: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230324172249-if00 adapter: ezsp
[2024-07-21 11:32:15] error: z2m: Error while starting zigbee-herdsman
[2024-07-21 11:32:15] error: z2m: Failed to start zigbee
[2024-07-21 11:32:15] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-21 11:32:15] error: z2m: Exiting...
[2024-07-21 11:32:16] error: z2m: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:370:19)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:164:13)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
HA recognises the adapter
config # ls /dev/serial/by-id/
However z2m won’t start
This is what I tried so far
- changing back the config to ezsp
- turn off HA machine and move dongle to different USB port
Is there anything else I can try?
Thank you
L:
