Hi, I switch to source routing firmware. I still have issue of the network. Bellow my log, Can someone give me an hint whats is wrong?
s6-init] making user provided files available at /var/run/s6/etcâŠexited 0.
[s6-init] ensuring user provided files have correct permsâŠexited 0.
[fix-attrs.d] applying ownership & permissions fixesâŠ
[fix-attrs.d] done.
[cont-init.d] executing container initialization scriptsâŠ
[cont-init.d] socat.sh: executingâŠ
[21:14:34] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executingâŠ
[21:14:34] INFO: MQTT available, fetching server detail âŠ
[21:14:34] INFO: Previous config file found, checking backup
[21:14:34] INFO: Creating backup config in â/config/zigbee2mqtt/.configuration.yaml.bkâ
[21:14:34] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks âŠ
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:14:34] INFO: Handing over control to Zigbee2mqtt Core âŠ
[email protected] start /app
node index.js
Zigbee2MQTT:warn 2021-07-13 21:14:46: permit_join
set to true
in configuration.yaml.
Zigbee2MQTT:warn 2021-07-13 21:14:46: Allowing new devices to join.
Zigbee2MQTT:warn 2021-07-13 21:14:46: Set permit_join
to false
once you joined all devices.
Zigbee2MQTT:error 2021-07-13 21:15:56: Publish âsetâ âstateâ to âDoor Entry1â failed: âError: Command 0x00158d00054eadd7/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Timeout - 29117 - 1 - 3 - 6 - 11 after 10000ms)â
Zigbee2MQTT:error 2021-07-13 21:16:55: Publish âsetâ âstateâ to âDoor Entry1â failed: âError: Command 0x00158d00054eadd7/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:17:34: Publish âsetâ âstateâ to âEntry Pole3â failed: âError: Command 0x00158d0005790ae1/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:17:41: Publish âsetâ âstateâ to âDoor Entry1â failed: âError: Command 0x00158d00054eadd7/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:18:57: Failed to execute LQI for âPool Pole1â
Zigbee2MQTT:error 2021-07-13 21:19:42: Failed to execute LQI for âEntry Pole3â
Zigbee2MQTT:error 2021-07-13 21:20:16: Failed to execute LQI for âDoor Entry1â
Zigbee2MQTT:error 2021-07-13 21:20:42: Failed to execute LQI for âDown Stairsâ
Zigbee2MQTT:error 2021-07-13 21:22:10: Failed to execute LQI for âDining Tableâ
Zigbee2MQTT:error 2021-07-13 21:22:40: Failed to execute LQI for âPool Balconyâ
Zigbee2MQTT:error 2021-07-13 21:29:34: Publish âsetâ âstateâ to âDoor Entry1â failed: âError: Command 0x00158d00054eadd7/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:31:36: Publish âsetâ âstateâ to âDown Stairsâ failed: âError: Command 0x00158d00054eae8f/2 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:31:56: Publish âsetâ âstateâ to âDown Stairsâ failed: âError: Command 0x00158d00054eae8f/2 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:32:17: Publish âsetâ âstateâ to âDown Stairsâ failed: âError: Command 0x00158d00054eae8f/2 genOnOff.off({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:32:32: Publish âsetâ âstateâ to âDining Tableâ failed: âError: Command 0x00158d0005c1318a/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:33:32: Publish âsetâ âstateâ to âDoor Entry1â failed: âError: Command 0x00158d00054eadd7/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:37:58: Publish âsetâ âstateâ to âPool Pole1â failed: âError: Command 0x00158d00054eaf2f/2 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:39:38: Publish âsetâ âstateâ to âPool Pole1â failed: âError: Command 0x00158d00054eaf2f/2 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:42:44: Publish âsetâ âstateâ to âPool Pole1â failed: âError: Command 0x00158d00054eaf2f/2 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:47:08: Publish âsetâ âstateâ to âPool Balconyâ failed: âError: Command 0x00158d0006269440/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:47:29: Publish âsetâ âstateâ to âPool Balconyâ failed: âError: Command 0x00158d0006269440/2 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:47:49: Publish âsetâ âstateâ to âPool Balconyâ failed: âError: Command 0x00158d0006269440/1 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:48:09: Publish âsetâ âstateâ to âPool Balconyâ failed: âError: Command 0x00158d0006269440/2 genOnOff.on({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:48:30: Publish âsetâ âstateâ to âPool Balconyâ failed: âError: Command 0x00158d0006269440/1 genOnOff.off({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:48:50: Publish âsetâ âstateâ to âPool Balconyâ failed: âError: Command 0x00158d0006269440/2 genOnOff.off({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
Zigbee2MQTT:error 2021-07-13 21:49:11: Publish âsetâ âstateâ to âPool Balconyâ failed: âError: Command 0x00158d0006269440/2 genOnOff.off({}, {âsendWhenActiveâ:false,âtimeoutâ:10000,âdisableResponseâ:false,âdisableRecoveryâ:false,âdisableDefaultResponseâ:false,âdirectionâ:0,âsrcEndpointâ:null,âreservedBitsâ:0,âmanufacturerCodeâ:null,âtransactionSequenceNumberâ:null,âwriteUndivâ:false}) failed (Data request failed with error: âNo network routeâ (205))â
