I have a problem with my philips hue since the last zigbee2mqtt update (I believe).
The dial behaves normally in the zigbe2mqtt integration. If I check the “state” and “expose” , everything behaves normally, all the information is there. In particular the action is shown (button press, hold, … as shown in Philips 8719514440937/8719514440999 control via MQTT | Zigbee2MQTT)
On the other end one of “action” entity in home assistant disappeared: sensor.<dial_name>_action. All others entities are present (step size, …).
Does anyone know if this could be a consequence of the update? Is there any way I can get back that entity?
P.S. re-pairing after force-remove does not solve the issue.
Hope someone can help!
Have a great day!
