Hello! I am using Zigbee 2 MQTT on another server and MQ is installed on CHAOS. I would like to know how it is correct to specify a broker in Zigbee 2 MQTT in order for the added devices to appear immediately in Home Assistant.
You should be able to point Z2M to your :1883. You’ll also need to provide the username and password setup in the MQTT addon.
Your config should look like this:
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.1.175:1883
user: ha_mqtt
password: 123412341234
I have tried that, but the new devices still do not appear in my HA.
Have you looked at the MQTT logs or used something like the MQTT tool to see what traffic (if any) is being passed?
Show your Zigbee2MQTT configuration. I use an external Zigbee2MQTT too, never had problems.
