Zigbee 3 (ZHA) Smart plug + Repeater
Here is a Zigbee 3 smart plug which also acts as a Repeater.
Installation was a breeze with Home Assistance.
This bridged the gap I needed for a sensor far back in the garage which was going online/offline frequently.
I was looking for a repeater which was Zigbee 3 and supported ZHA in order to get the new standards going forward. I was also looking for something quick and easy to install.
I will be honest, its larger than I expected. Being plugged in the lower socket does cover the entire wall outlet.
Wasn’t too concerned as it does have a single controlled plug and the fact I have never used the A/C outlet in the laundry room
  • Hass.io 80.1
  • Linear HUSBZB-1 (Configured as ZHA, not zigbee).
Installation: Plug in, press the button until light flashes, ZHA Permit to discover.
Discovers as a light:
light.feibit_fnb56skt1ehg12_0292xxxxxx_xx
zha.zha_feibit_fnb56skt1ehg12_0292xxxxxx
Smart ZigBee Plug Socket
Do they make these with proper voltages and different plug configurations?
I like the look of this device. Pity it detects as a light rather than a switch, but I could live with that.
Hopefully I can find one that runs at 240V with AU plug configurations.
Edit: ZHA is the correct component to use. ZigBee is a different component more aimed at XBEE modules and point to point communication. :slight_smile:
Quick update.
Been using the device for a while. However, any power hiccup or fluctuation it plays havoc on the devices being relayed through. Ended up removing the device with something different.
What did you end up switching to? I’ve got a HUSBZB-1 hooked up to my NAS (which is running Home assistant as a VM) in the basement, but the range leaves something to be desired. I’ve found I can use a couple of my lightbulbs as repeaters but those occasionally get flicked off at a switch. Hoping to find something I can just plugin out of the way to improve the zigbee network.
I also have a Synology Server with HA running in a VM, passing the USB port through to the VM instance.
Here is what I’m using for the controller and been flawless for me:
https://www.amazon.com/gp/product/B01GJ826F8/ref=ox_sc_saved_title_3?smid=A36RV344P5JWP3&psc=1
Here are three devices which I’ve placed around the house in order to ack as repeaters.
ZHA:
https://www.amazon.com/gp/product/B019HTH2A0/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01M6UM8QD/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
ZWave:
https://www.amazon.com/gp/product/B01M6CKJXC/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Cause I have my TVs/Serio’s, etc on surge protectors and Cable boxes/Laptops on battery backups, I’ve plugged them into the battery backups side so they don’t go down during power flickers.
Hope this helps…
