I have bought a 4 button remote from aliexpress: 4 Button remote
Added with the Zigbee integration into home assistant.
That all worked in 1 go.
But when i press a button on the remote nothing changes in home assistant.
The led on the remote works fine, indicating that it “works”
But no state change in HA. (other zigbee devices work fine).
I have a SS6400ZB-V2 (that’s on the box)
Futher more, HA is the latest version.
What do you mean with firmware (i know what is this) but of which device?
Updated the conbee II (firmware was from 2019, now the latest)
Then checked the remote, no change.
Removed the device from the zigbee network. re-added, still does not work.
Also i dont see any event when listening for zha_event.
So whats next.
under the add device page:
[0xa33b:1:0x0006] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=23 command_id=253>
[0xa33b:1:0x0006] Unknown cluster-specific command 253
[0xa33b:1:0x0006] ZCL request 0x00fd: b’\x00’
[0xa33b:1:0x0006] No handler for cluster command 253
[0xA33B:1:0x0006]: received ‘253’ command with b’\x00’ args on cluster_id ‘6’ tsn ‘23’
[0xa33b:1:0x0006] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=25 command_id=253>
and on the HA log page:
Logger: zigpy.zcl
Source: /usr/local/lib/python3.9/site-packages/zigpy/zcl/init.py:114
First occurred: 11:25:38 (208 occurrences)
Last logged: 15:54:41
