how you do this?
Unfortunately (but that may be a tip), AM43 was a reaon that I switched from Phoscon to Zigbee2MQTT. So I can not help with Phoscon.
Ok I ordered the new Home Assistant Zigbee stick, when will arrive I will move all my zigbee devices to it
Hi, I just moved all my Zigbee to z2m, so far so good. I included the AM43, but when I click OPEN or CLOSE the rope turns only less then 1 sec and then it stops.
Any hint?
Change the motor from dot mode (default) to continuous mode.
Where is this settings? In zigbee2mqtt? Can’t find it
Ahh on the blind … but when I press the button phisically it is continuous (I do have to press the button once and then it starts).
Anyway thanks will try it onb the device when I am back home.
EDIT: works, thanks
