Zigbee Automation
I moved a couple of Xiaomi aqara motion sensor from Xiaomi Gateway to HA Zigbee Home Automation. The motion is detected but the battery (power) level always shows 100% even though I know the sensor’s battery is over a year old. Is there a fix for this?
Hi, I have always had the sensors directly on HA via a USB gateway, but since a few weeks after updating the OS I have the same “problem” as you.
Before the update certain sensors were between 80 and 95 %, now they are all at 100 for a few weeks now.
N.
So at one time it works when connected directly to HA?
I switched them back to Xiaomi gateway and all readings are back to normal (ie. battery level no longer 100% all the time).
