Zigbee Bridge
Hi there,
Today i started installing a Zigbee Bridge with Tasmota.
After succesful flashing and setting the thing up i started moving my devices.
All went without problems and all devices have been moved. But… There is always a but.
After removing Zigbee2MQTT and Mosquito Broker things are getting a bit weird. When i restart Home Assistant i get the following message (after the restart)
Invalid config
The following integrations and platforms could not be set up:
* mqtt
* mqtt.sensor
* mqtt.switch
Please check your config.
What’s going on here?
You disabled the MQTT broker, resulting in all devices that you configured to use MQTT will no longer work.
I know. But why do i get this message when restarting Home Assistant?. I have no MQTT devices configured used the configuration.yaml. All entities configured using Zigbee2MQTT are gone.
Do you have the MQTT integration configured via configuration.yaml by any chance?
Found the solution.
Had a file called Zigbee2MQTT in a “packages” folder. Used it for renaming and removing stuff that won’t be removed from within the entities list.
