I (re)configure my zigbee2MQTT to use the channel 26 (i’ve moved to a new house).
Before i was using the channel 11 and it looks that the link quality was better (less walls also), most of my device are Aqara/Xiaomi.
Someone could say me if for example changing the zigbee channel to 25 (or something else), could give me a better link quality ? Or the “poor” quality will be the same changing the channel ?
Another idea, if i put a router with CC2531, the quality could be better also to expand the range of the network ?
I ask this question, to see if i need to (re)pairing all devices (with another channel) to check if the link quality is better or not.
For information, the wifi channel uses by neighboordhoud, it’s 1/6/11. So normally the interference should be ok at this point.
Thank for your feedback.
