tl;dr Can I get this SmartThings Outlet to talk directly to this Xbee coordinator? Namely without having a SmartThings hub.
Background. I am brand new to Home Assistant and home automation in general. As a maker, electronics hobbiest, and programmer, I am coming at this a bit different than most. I have the above Xbee radio (setup as a coordinator) plugged into my Raspberry Pi, which is running Hassio/HomeAssistant. As a simple test I picked up the above SmartThings Outlet, and want to control it via Home Assistant.
I was hoping to use XCTU and scan and find the SmartThings Outlet. But its not of course, not without AT LEAST knowing the PAN ID set in the outlet. I assume there is more though. Most of the resources I find on this involve having a SmartThings hub and joining into an existing network, then copying security settings and stuff. But again, I dont have a SmartThings Hub.
Does anyone know if I can accomplish this with my setup? If not, is there another zigbee outlet that will?
