I have a RPI 4B with a Sonoff Zigbee 3.0 USB antenna as controller. Everything worked fine previously, but my configuration got lsot and I have an issue reconfiguring it againa.
I have docker with HA, Mosquitto and Zigbee2MQTT.
All containers seem to run fine and Zigbee2MQTT works fine, as I can connect to the frontend and see my zigbee devices.
The only issue I have is the integration with HA.
Adding MQTT works, but it doesn’t show my devices I can see in zigbee2mqtt.
Adding the Zigbee integration in HA fails. It proposes to connect to /dev/ttyUSB0, which I modify, as my Sonoff is at /dev/ttyUSB1. But neiter port and setting (software, hardware,…) doesn’t make any connection.
Where should I look to get the zigbee integration working in HA again?
