HI there!
RPI4 with ssd
HA Version 0.112.4
cc2531 usb zigbee stick with external antenna
since sunday i have trouble with my zigbee network, to turn on my lights.
i have no clue where to look for, since nothing has changed and it suddenly stopped working.
zigbee2mqtt i use, the log says this:
zigbee2mqtt:error 2020-07-28 20:20:43: Publish 'set' 'state' to 'Inbouwspot Keuken 3' failed: 'Error: Command 0x14b457fffe2d8ee2/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Timeout - 47478 - 1 - 222 - 6 - 11 after 10000ms)'
zigbee2mqtt:info 2020-07-28 20:20:43: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"zigbee_publish_error","message":"Publish 'set' 'state' to 'Inbouwspot Keuken 3' failed: 'Error: Command 0x14b457fffe2d8ee2/1 genOnOff.on({}, {\"timeout\":10000,\"disableResponse\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null}) failed (Timeout - 47478 - 1 - 222 - 6 - 11 after 10000ms)'","meta":{"friendly_name":"Inbouwspot Keuken 3"}}'
i don’t know where to start looking, since its not a clear error message, for me at least
Signal quality must be good, since it was good when it still worked, and what i want to power on over the network are routers also.
This one down is an in-wall switch, used to work good also, i do think this is the cause, i can power it on manually on the wall, but no state change in HA or the zigbee log
zigbee2mqtt:info 2020-07-28 20:26:55: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"zigbee_publish_error","message":"Publish 'set' 'state' to 'Eettafel' failed: 'Error: Command 0xec1bbdfffe803b85/1 genOnOff.on({}, {\"timeout\":10000,\"disableResponse\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null}) failed (Timeout - 61936 - 1 - 6 - 6 - 11 after 10000ms)'","meta":{"friendly_name":"Eettafel"}}'
Can you point me in a direction? thanks!
