Zigbee connectivity issue
I powered off one zigbee led light which is a router then two zigbee lights no longer worked since they still trying connect to the led. Will they able to figure out and connect to other routers? Or how can I manually fix for them?
They will try to reroute on their own, but it can take up to 24 hours (sometimes more) depending on the number of devices you have in your mesh.
Total 11 zigbee devices. That seems too long, is there anything I can do to speed it up? I am using zigbee2mqtt
For 11 devices, it should take around an hour (maybe less). It largely depends on the devices and the coordinator on how long it takes a device to reroute.
You can’t really do much to speed it up aside from unpairing the devices and rejoining them which will create new routes immediately.
You could re-pair those devices and they’d then connect to a different routing node.
