Zigbee coordinator CC2531 vs CC2652p experience
Hi I want to share my experience with the zigbee coordinator.
I have been using CC2531 for a long time.
  • It was cheap
  • With external antenna
  • supported zigbee2mqtt and many devices
  • was connected via a USB extension
Then, over time, it stopped working. It was always necessary to remove and insert the USB. It is now marked as an unsupported device on the official website.
I switched to CC2652p with 6dB antenna.
  • I recomend
  • signal stable
  • light flash
  • during the transition without problems. No device pairing was required. They all worked.
  • but it’s so expensive once.
I use two more tradify routers from ikei and Webee CC2530 + CC2591. They work great.
Thank you for sharing your experience.
Could u suggest some CC2652p routers(like plug or relays 24x7 power) to form a reliable and solid Zigbee mesh network.
