Hello, I have a couple of Zigbee devices that I want to continue to use with a light switch without electricity.
As a result, I always have problems with other devices that were currently connected to this device after switching off.
That’s why I want to deactivate the repeater function for a few devices.
Is this possible and how? I am very grateful for help.
Here is an example device:
371232040
von Paulmann Licht
IEEE: 00:15:8d:00:05:81:dd:b0
Nwk: 0x316b
Device Type: Router
LQI: 255
RSSI: -58
SIGNATURE:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4624, maximum_buffer_size=127, maximum_incoming_transfer_size=90, server_mask=11264, maximum_outgoing_transfer_size=90, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x010c",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x0300",
"0x1000"
"out_clusters": [
"0x0019"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [
"0x0021"
"out_clusters": [
"0x0021"
"manufacturer": "Paulmann Licht",
"model": "371232040",
"class": "zigpy.device.Device"
This device has the following entity:
light.lc10_paulmann_level_light_color_on_off
Greetings Werner
