Not totally sure where I should ask this.
The situation is a newly bought rain sensor, Tuya RB-SRAIN01. I’m having slight issues because the low sunlight means the battery is struggling and it’s dropping off the network at night.
The trick is… come the morning it does not seem to come back “online” - I’ve got to re-pair it… and enter the rinse and repeat cycle.
I get the following on an interview…
info 2024-12-14 09:14:18z2m: Interviewing 'Rain Sensor'
error 2024-12-14 09:14:19zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-12-14 09:14:19zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
info 2024-12-14 09:14:28z2m: Successfully interviewed 'Rain Sensor'
info 2024-12-14 09:14:28z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/interview', payload '{"data":{"id":"Rain Sensor"},"status":"ok","transaction":"og363-1"}'
So I’m not sure what to make of this. On the face of it, it looks like I’m going to have to re-pair this device every time the battery runs flat.
Grateful for thoughts, before I consider cutting it open (destroying the rain protection) and hooking in an extra solar panel or something.
