Could i please ask for your support, since the latest update i am loosing my mind as i cannot use my zigbee devices in automations. Please check below:
I have a motion sensor in the WC which is set up correctly and it detects motion:
I noticed that this happens with all my zigbee devices. I can find their states, but i cannot find them as devices. For the motion sensors, that’s ok because at least i can build automations via their state. But i have a big problem with the buttons as they don’t have state entities. In the past they were devices and had short, long or double press actions on it. Now i cannot find them too as devices.
Sorry the screenshot is from my phone, I am away from my computer.
Just to say that because of this, I made a clean install and its the same also there… I also tried to change the “show as” option but it doesn’t change anything
If it is a usb stick for zigbee…
Remove it…and plug it back in…
I had the same issue since last updates
And I’ve did somewhere in ha to do this
It solved my problem…
Worth to try
I think we established on github that the issue is not with the zha integration as the devices exist if you scroll the list. The issue seems to be with the frontend not pulling the device friendly name from the database. I think i saw a pull request that fixes the issue but it wasn’t implemented in 2023.07.02 version as there there was no frontend update.
