I moved my coordinator, and now my Zigbee routers seem like they’re no longer talking to each other. Here are the details:
- My network was built with the coordinator in Room A and everything worked great
- I unplugged the coordinator, moved it to Room B, and waited 30+ minutes before plugging it back in (apparently, this will trigger a network heal?)
- Both Room A and B had at least 2 routers with line of sight to the coordinator within 3m
- I left the coordinator in Room B for 24 hours to let things re-route
- I checked the network map and noticed, most devices appear to be orphaned. The few that are still in the graph only have direct connections to the coordinator and not each other (see “Coordinator in Room B”)
- I moved the coordinator back to the original locaiton and things work well again (see “Coordinator in Room A”)
So the question is:
- Why does the network breaks down after moving the coordinator? I was under the impression that since previously all the routers had reasonable connections to one another (directly or indirectly), the network would continue to work well as long as the coordinator was still able to talk to at least one of the routers in the network.
- Bonus question: Is there any way to programmatically force a re-healing? I have googled this, and I know the answer is probably “no, unplug it and wait” but something about that seems off to me.
Coordinator in Room B:
