Addition (Logs):
17:03:15:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:15:118 Skip automatic channel change, TODO warn user
17:03:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:25:119 Skip automatic channel change, TODO warn user
17:03:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:35:119 Skip automatic channel change, TODO warn user
17:03:37:114 remove link for (0, 46BF)
17:03:39:995 remove link for (0, E253)
17:03:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:45:118 Skip automatic channel change, TODO warn user
17:03:55:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:55:118 Skip automatic channel change, TODO warn user
17:04:05:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:05:118 Skip automatic channel change, TODO warn user
17:04:07:753 ZCL attribute report 0x54EF441000BEFC23 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
17:04:07:779 ZCL attribute report 0x54EF441000BEFC23 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
17:04:13:115 remove link for (0, 9F66)
17:04:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:15:119 Skip automatic channel change, TODO warn user
17:04:15:944 remove link for (0, E253)
17:04:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:25:119 Skip automatic channel change, TODO warn user
17:04:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:35:119 Skip automatic channel change, TODO warn user
17:04:45:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:45:119 Skip automatic channel change, TODO warn user
17:04:50:075 remove link for (0, 46BF)
17:04:52:955 remove link for (0, E253)
17:04:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:55:119 Skip automatic channel change, TODO warn user
17:05:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:05:119 Skip automatic channel change, TODO warn user
17:05:15:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:15:118 Skip automatic channel change, TODO warn user
17:05:25:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:25:118 Skip automatic channel change, TODO warn user
17:05:27:019 remove link for (0, 9F66)
17:05:29:914 remove link for (0, 46BF)
17:05:35:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:35:118 Skip automatic channel change, TODO warn user
17:05:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:45:118 Skip automatic channel change, TODO warn user
17:05:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:55:119 Skip automatic channel change, TODO warn user
17:06:03:515 remove link for (0, E253)
17:06:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:05:119 Skip automatic channel change, TODO warn user
17:06:06:395 remove link for (0, 9F66)
17:06:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:15:119 Skip automatic channel change, TODO warn user
17:06:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:25:119 Skip automatic channel change, TODO warn user
17:06:35:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:35:118 Skip automatic channel change, TODO warn user
17:06:39:080 DeviceAnnce of SensorNode: 0x54EF441000B3D37C [1]
17:06:40:269 remove link for (0, 46BF)
17:06:41:102 ZCL attribute report 0x54EF441000B3D37C for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
17:06:42:875 remove link for (0, E253)
17:06:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:45:118 Skip automatic channel change, TODO warn user
17:06:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:55:119 Skip automatic channel change, TODO warn user
17:07:03:286 ZCL attribute report 0x54EF441000B3D37C for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
17:07:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:05:119 Skip automatic channel change, TODO warn user
17:07:15:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:15:118 Skip automatic channel change, TODO warn user
17:07:18:395 remove link for (0, E253)
17:07:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:25:119 Skip automatic channel change, TODO warn user
17:07:35:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:35:118 Skip automatic channel change, TODO warn user
17:07:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:45:118 Skip automatic channel change, TODO warn user
17:07:53:915 remove link for (0, 46BF)
17:07:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:55:119 Skip automatic channel change, TODO warn user
17:08:05:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:05:118 Skip automatic channel change, TODO warn user
17:08:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:15:119 Skip automatic channel change, TODO warn user
17:08:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:25:119 Skip automatic channel change, TODO warn user
17:08:28:955 remove link for (0, E253)
17:08:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:35:119 Skip automatic channel change, TODO warn user
17:08:45:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:45:119 Skip automatic channel change, TODO warn user
17:08:55:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:55:118 Skip automatic channel change, TODO warn user
17:08:58:096 ZCL attribute report 0x54EF441000B397BF for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
17:09:03:995 remove link for (0, 46BF)
17:09:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:09:05:119 Skip automatic channel change, TODO warn user
17:09:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:09:15:119 Skip automatic channel change, TODO warn user
17:09:25:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:09:25:118 Skip automatic channel change, TODO warn user
17:09:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
