Zigbee Devices not available after Power loss
Hello Guys
I use the ConBee III Stick as Zigbee hub. Previously (as you can see in my question-history) I had massive Zigbee problems. Thankfully, I found solutions, thanks to you guys in this forum.
Everything worked fine until now.
So the problem is, there was a power outage because some electrician had to do some work at home. Normally, when this happens, HA restarts and connects all devices again. Not this time.
What happened is:
All devices reconnected to Deconz. I can see this in the Deconz Add-on. So, Devices reconnected to the hub.
But all devices in HA are not available. Like if Decons didn’t match the device status it has on deconz with the HA devices. If you know what I mean. Really strange. Any idea how and why and how I can fix it?
Addition (Logs):
17:03:15:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:15:118 Skip automatic channel change, TODO warn user
17:03:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:25:119 Skip automatic channel change, TODO warn user
17:03:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:35:119 Skip automatic channel change, TODO warn user
17:03:37:114 remove link for (0, 46BF)
17:03:39:995 remove link for (0, E253)
17:03:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:45:118 Skip automatic channel change, TODO warn user
17:03:55:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:03:55:118 Skip automatic channel change, TODO warn user
17:04:05:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:05:118 Skip automatic channel change, TODO warn user
17:04:07:753 ZCL attribute report 0x54EF441000BEFC23 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
17:04:07:779 ZCL attribute report 0x54EF441000BEFC23 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
17:04:13:115 remove link for (0, 9F66)
17:04:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:15:119 Skip automatic channel change, TODO warn user
17:04:15:944 remove link for (0, E253)
17:04:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:25:119 Skip automatic channel change, TODO warn user
17:04:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:35:119 Skip automatic channel change, TODO warn user
17:04:45:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:45:119 Skip automatic channel change, TODO warn user
17:04:50:075 remove link for (0, 46BF)
17:04:52:955 remove link for (0, E253)
17:04:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:04:55:119 Skip automatic channel change, TODO warn user
17:05:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:05:119 Skip automatic channel change, TODO warn user
17:05:15:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:15:118 Skip automatic channel change, TODO warn user
17:05:25:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:25:118 Skip automatic channel change, TODO warn user
17:05:27:019 remove link for (0, 9F66)
17:05:29:914 remove link for (0, 46BF)
17:05:35:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:35:118 Skip automatic channel change, TODO warn user
17:05:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:45:118 Skip automatic channel change, TODO warn user
17:05:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:05:55:119 Skip automatic channel change, TODO warn user
17:06:03:515 remove link for (0, E253)
17:06:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:05:119 Skip automatic channel change, TODO warn user
17:06:06:395 remove link for (0, 9F66)
17:06:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:15:119 Skip automatic channel change, TODO warn user
17:06:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:25:119 Skip automatic channel change, TODO warn user
17:06:35:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:35:118 Skip automatic channel change, TODO warn user
17:06:39:080 DeviceAnnce of SensorNode: 0x54EF441000B3D37C [1]
17:06:40:269 remove link for (0, 46BF)
17:06:41:102 ZCL attribute report 0x54EF441000B3D37C for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
17:06:42:875 remove link for (0, E253)
17:06:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:45:118 Skip automatic channel change, TODO warn user
17:06:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:06:55:119 Skip automatic channel change, TODO warn user
17:07:03:286 ZCL attribute report 0x54EF441000B3D37C for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
17:07:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:05:119 Skip automatic channel change, TODO warn user
17:07:15:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:15:118 Skip automatic channel change, TODO warn user
17:07:18:395 remove link for (0, E253)
17:07:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:25:119 Skip automatic channel change, TODO warn user
17:07:35:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:35:118 Skip automatic channel change, TODO warn user
17:07:45:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:45:118 Skip automatic channel change, TODO warn user
17:07:53:915 remove link for (0, 46BF)
17:07:55:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:07:55:119 Skip automatic channel change, TODO warn user
17:08:05:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:05:118 Skip automatic channel change, TODO warn user
17:08:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:15:119 Skip automatic channel change, TODO warn user
17:08:25:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:25:119 Skip automatic channel change, TODO warn user
17:08:28:955 remove link for (0, E253)
17:08:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:35:119 Skip automatic channel change, TODO warn user
17:08:45:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:45:119 Skip automatic channel change, TODO warn user
17:08:55:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:08:55:118 Skip automatic channel change, TODO warn user
17:08:58:096 ZCL attribute report 0x54EF441000B397BF for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
17:09:03:995 remove link for (0, 46BF)
17:09:05:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:09:05:119 Skip automatic channel change, TODO warn user
17:09:15:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:09:15:119 Skip automatic channel change, TODO warn user
17:09:25:118 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
17:09:25:118 Skip automatic channel change, TODO warn user
17:09:35:119 apsUseExtPanid is 0x90E0C6C88A80AFB9 but should be 0, start reconfiguration
Any update on your issue? I see these logs as well.
Hey
Yes, it started working again.
But this issue was because of another one. How I solved the other issue, you can read here:
Zigbee stuck on Interview - Configuration / Zigbee - Home Assistant Community
Have a nice weekend.
