Thanks Interloping,
I still consider that fix to be a problem because this isn’t how zigbee lights should behave. But thank you, I think this may help narrow one or two of the issues down a bit and it’s definitely worth including with my data when I finally send it to them.
I’ve redone the test where we can get the light stuck in the on state, but with 0.1s set as the transition time. But I haven’t had a chance to rerun other tests with this change yet.
Test Steps:
- Start light at 100% brightness.
- Turn light off.
- Turn light on with a 20% brightness.
Test Variables
- Transition time
- Where transition time is set.
No Transition Time (default)
Result:
The light turned on with 20% brightness, but got stuck and can’t turn off.
Transition time too fast to check.
Coordinator Message - Turn On
ZigBee Cluster Library Frame
Frame Control Field: Cluster-specific (0x01)
.... ..01 = Frame Type: Cluster-specific (0x1)
.... .0.. = Manufacturer Specific: False
.... 0... = Direction: Client to Server
...0 .... = Disable Default Response: False
Sequence Number: 58
Command: Move to Level with OnOff (0x04)
Payload
Level: 51
Transition Time: 0.0 seconds
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 58
Frame Control Field: Profile-wide (0x18)
.... ..00 = Frame Type: Profile-wide (0x0)
.... 1... = Direction: Server to Client
...1 .... = Disable Default Response: True
Sequence Number: 58
Command: Default Response (0x0b)
Response to Command: 0x04
Status: Success (0x00)
Coordinator Message - Turn Off
Sequence Number: 59
Command: Off (0x00)
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 59
Sequence Number: 59
Response to Command: 0x00
Transition = 0.1 attached to the message alongside brightness
Result:
Sequence Number: 66
Payload
Level: 51
Transition Time: 0.1 seconds
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 66
Sequence Number: 66
Sequence Number: 67
Command: Off (0x00)
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 67
Sequence Number: 67
Transition = 0.1 from Z2M Settings (Specific) Menu
The light turned on with 20% brightness, and then turned off.
Sequence Number: 75
Payload
Level: 51
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 75
Sequence Number: 75
Sequence Number: 76
Payload
Level: 0
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 76
Sequence Number: 76
Transition = 0.1 from Z2M Settings (Specific) Menu but 1.0s attached to the message alongside brightness
Result:
The light transitioned instantly. As expected, the transition time that was manually added to the message overwrote the settings menu, but the transition time was ignored.
Sequence Number: 90
Payload
Level: 51
Transition Time: 1.0 seconds
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 90
Sequence Number: 90
Sequence Number: 91
Payload
Level: 0
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 91
Sequence Number: 91
Transition = 1.0s from Z2M Settings (Specific) Menu
Result:
The light transitioned instantly and ignored the 1.0s setting.
Sequence Number: 109
Payload
Level: 51
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 109
Sequence Number: 110
Payload
Level: 0
Light Response
ZigBee Cluster Library Frame, Command: Default Response, Seq: 110
