Anyone knows of a good a ZigBee dimmer that works with two way switches instead of push buttons (to be mounted behind the switch)?
Obviously I won’t be able to set the intensity by pushing the switch, but at least I avoid replacing all 4 spot lights with smart ones…
I looked at Sunricher and Wiser but both works with push buttons.
Hellis81
(Hellis81)
May 25, 2024, 11:26am
2
What do you mean by push button?
You mean you have to push the button to turn them on?
If so that is false.
I have a sunricher dimmer and the button is just momentary.
I haven’t tried, but I believe two of them could work in a group to control one lamp
Hi, I may have used the wrong term in English.
All my switches are the left ones, not the right ones
Hellis81
(Hellis81)
May 25, 2024, 2:05pm
4
Yeah… that is what a usual switch is.
But if you are planning on replacing that with a dimmer then what does that matter?
Maybe I’m not seeing something but usually you remove everything and install the dimmer in it’s place.
Yeah I agree, I don’t know how the others are called that is why I went with “push buttons”.
There are modules you can mount behind existing switches such as:
https://www.productinfo.schneider-electric.com/wiser_home/wiser-micro-module-dimmer_device-user-guide_wiser-home/English/Wiser_Micro_Module_Dimmer_Wiser_Home_Device%20user%20guide_0000776029.xml/$/Wisermicromoduledimmer_CCT5010-0002W_0000733430
But they don’t work with classic switches as you can see in the installation guide (and the custom are service confirmed). I found Z-Wave that do the job but no ZigBee…
Hellis81
(Hellis81)
May 26, 2024, 7:41am
6
I’m not following.
Is a dimmer like this you want?
Or is it a behind the wall option you want?
