“”“Tuya based touch switch.”“”
from typing import Optional, Union
from zigpy.profiles import zha
from zigpy.quirks import CustomCluster
import zigpy.types as t
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import Basic, GreenPowerProxy, Groups, Identify, LevelControl, OnOff, Ota, Scenes, Time
from zigpy.zcl.clusters.lighting import Color
from zhaquirks.const import (
DEVICE_TYPE,
ENDPOINTS,
INPUT_CLUSTERS,
MODELS_INFO,
OUTPUT_CLUSTERS,
PROFILE_ID,
from zhaquirks.tuya import (
TuyaDimmerSwitch,
TuyaLevelControl,
TuyaManufacturerClusterOnOff,
TuyaManufacturerLevelControl,
TuyaManufCluster,
TuyaOnOff,
from zhaquirks.tuya.mcu import (
TuyaInWallLevelControl,
TuyaLevelControlManufCluster,
TuyaOnOff as TuyaOnOffMCU,
class TuyaSingleSwitchDimmerPlus(TuyaDimmerSwitch):
“”“Tuya touch switch device.”“”
signature = {
# "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0,
# reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>,
# manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82,
# descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False,
# *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
MODELS_INFO: [
("_TZE200_swaamsoy", "TS0601"),
ENDPOINTS: {
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.DIMMER_SWITCH,
INPUT_CLUSTERS: [
Basic.cluster_id,
Identify.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
OnOff.cluster_id,
LevelControl.cluster_id,
Color.cluster_id,
TuyaManufCluster.cluster_id,
OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
replacement = {
ENDPOINTS: {
1: {
DEVICE_TYPE: zha.DeviceType.ON_OFF_LIGHT,
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaOnOffMCU,
