Hello everyone!
I have a question about HA + idinio trailing edge dimmer + ledtstrip Triac driver + led strip.
When I turn on the electricity, and use manual dimmer for the first time - it simms to max and min and turns on and off, beautiful transition.
But when I do it via HA, or Google voice, like ‘dim to 50%’ it works, but it decides it is a nex maximum and never goes higher not manually not logically.
When I turn off electricity in the house and turn on again, dimms again to full brightness.
A couple thoughts
1 - a dimmer is recognized by HA as a floor dimmer and not as a wall dimmer
2 - brightness scale is recognized as 254 (have no idea though what it means yet)
3 - when I see messages they are coming and showing brightness at 3 as min, 254 as max, and around 130 as mid.
I use this dimmer also with halogen dimmable lamps and don’t have any problems.
This dimmer is the only affordable dimmer I can buy in the NL and plus it works with normal electricity plates from Gira Jung and etc. That’s why I choose it.
If anyone has any suggestions or ideas - I would be super thankful!!
