Does someone have experience with the Zigbee Dimmer in combination with Filament light bulbs from Calex?
I was not able to use the Fibaro Dimmer 2, The Qubina dimmer, or the Qubino Mini dimmer because the lights were flickering (even with a bypass) and it wasn’t stable or compatible with the Calex lights. So I saw a review online that the Zigbee Dimmer had no problem with dimming the Filament Calex lights.
Also, is it possible to control the lights with Google Assistant trough Home assistant?
