Hi all, I’m trying to pass though a zigbee stick to HA via docker, The stick shows up in device manger on windows. But when I run ls -l /dev/serial/by-id
all it shows is this. ls: cannot access ‘/dev/serial/by-id’: No such file or directory
any help would be great.
Don’t use Docker on Windows? That’s not a supported installation method. If you want to run on Windows, you’d need to use a VM with a hypervisor (VMWare Fusion Player, VirtualBox, etc).
Im already running HA on proxmox on a intel Nuc which is rock solid just noisy.
I have a massive pc which i built so i would like it all on one machine.
