Zigbee dont work correct, some lags
Hi, after my old HA crashed, i restore it from a backup.
Then i got a lot of lags, i try to reinstall Deconz. But the problem is the same. My Hue Dimmer maybe dont work some times, some times it works, some times it lags, so make the lights on 5-10 sek later, sometimes does nothing…
Can someone help me?
I have the Deconz on my Pi
here the logs from today:
08:37:51:442 skip binding for attribute reporting of ep: 0x00 cluster 0x1000 (end-device might sleep)
08:37:52:385 Skip idle timer callback, too early: elapsed 944 msec
08:38:09:836 Bind response success for 0x001788010212cad8 ep: 0x02 cluster: 0x0406
08:38:09:838 skip configure report for cluster: 0x0406 attr: 0x0000 of node 0x001788010212CAD8 (seems to be active)
08:38:10:376 ZCL configure reporting rsp seq: 52 0x001788010212CAD8 for ep: 0x02 cluster: 0x0406 attr: 0x0030 status: 0x00
08:38:16:079 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:38:18:813 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:38:18:941 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:38:20:827 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0008, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:38:32:451 Device TTL 2921 s flags: 0x7
08:38:52:386 skip binding for attribute reporting of ep: 0x00 cluster 0x1000 (end-device might sleep)
08:39:03:390 ZCL attribute report 0x0017880103289A06 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:39:16:458 ZCL attribute report 0x0017880104F6CABD for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:39:26:221 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:39:27:559 ZCL attribute report 0x0017880103CAB325 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:39:32:438 Device TTL 2861 s flags: 0x7
08:39:37:146 ZCL attribute report 0x0017880103289A06 for cluster: 0x0402, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:39:41:400 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:39:41:459 Bind response success for 0x001788010212cad8 ep: 0x02 cluster: 0x0406
08:39:41:460 skip configure report for cluster: 0x0406 attr: 0x0000 of node 0x001788010212CAD8 (seems to be active)
08:39:42:000 ZCL configure reporting rsp seq: 128 0x001788010212CAD8 for ep: 0x02 cluster: 0x0406 attr: 0x0030 status: 0x00
08:39:52:386 skip binding for attribute reporting of ep: 0x00 cluster 0x1000 (end-device might sleep)
08:39:54:386 Skip idle timer callback, too early: elapsed 941 msec
08:40:23:386 skip binding for attribute reporting of ep: 0x00 cluster 0x1000 (end-device might sleep)
08:40:26:728 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0300, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:40:31:003 ZCL attribute report 0x00178801021B226A for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:40:32:444 Device TTL 2801 s flags: 0x7
08:40:35:840 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:40:35:875 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:41:18:387 skip binding for attribute reporting of ep: 0x00 cluster 0x1000 (end-device might sleep)
08:41:19:860 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:41:19:934 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:41:19:954 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:41:32:437 Device TTL 2741 s flags: 0x7
08:41:52:022 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0402, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:41:58:386 Skip idle timer callback, too early: elapsed 817 msec
08:42:26:173 ZCL attribute report 0x0017880103289A06 for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:42:32:436 Device TTL 2681 s flags: 0x7
08:42:36:070 ZCL attribute report 0x0017880104AF1828 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:42:39:160 ZCL attribute report 0x0017880104F6B4F3 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:42:59:385 Skip idle timer callback, too early: elapsed 926 msec
08:43:14:182 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:43:17:730 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:43:17:875 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:43:19:889 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0008, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:43:32:465 Device TTL 2621 s flags: 0x7
08:43:47:610 Announced to internet https://phoscon.de/discover
08:43:47:612 discovery server date: Mon, 21 Mar 2022 07:43:47 GMT
08:43:47:613 	 local time seems to be ok
08:44:02:893 ZCL attribute report 0x0017880103289A06 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:44:04:877 ZCL attribute report 0x00158D00067CE971 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
08:44:05:004 ZCL attribute report 0x00158D00067CE971 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
08:44:05:100 ZCL attribute report 0x00158D00067CE971 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
08:44:17:555 ZCL attribute report 0x0017880104F6CABD for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:44:25:631 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:44:28:664 ZCL attribute report 0x0017880103CAB325 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:44:32:444 Device TTL 2561 s flags: 0x7
08:44:36:712 ZCL attribute report 0x0017880103289A06 for cluster: 0x0402, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:44:40:852 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:45:26:244 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0300, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:45:32:134 ZCL attribute report 0x00178801021B226A for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:45:32:441 Device TTL 2501 s flags: 0x7
08:45:34:934 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:45:34:953 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:46:03:386 Skip idle timer callback, too early: elapsed 939 msec
08:46:18:916 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:46:18:984 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:46:19:004 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:46:32:446 Device TTL 2441 s flags: 0x7
08:46:51:546 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0402, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:47:03:386 Skip idle timer callback, too early: elapsed 945 msec
08:47:25:733 ZCL attribute report 0x0017880103289A06 for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:47:32:439 Device TTL 2381 s flags: 0x7
08:47:37:175 ZCL attribute report 0x0017880104AF1828 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:47:40:261 ZCL attribute report 0x0017880104F6B4F3 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:48:04:808 Skip idle timer callback, too early: elapsed 1 msec
08:48:05:386 Skip idle timer callback, too early: elapsed 578 msec
08:48:12:630 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:48:16:958 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:48:17:329 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:48:18:954 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0008, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:48:32:437 Device TTL 2321 s flags: 0x7
08:49:02:360 ZCL attribute report 0x0017880103289A06 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:49:18:653 ZCL attribute report 0x0017880104F6CABD for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:49:25:130 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:49:29:783 ZCL attribute report 0x0017880103CAB325 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:49:32:441 Device TTL 2261 s flags: 0x7
08:49:36:088 ZCL attribute report 0x0017880103289A06 for cluster: 0x0402, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:49:40:349 ZCL attribute report 0x001788010212CAD8 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:50:01:735 0x001788010226D0B0 error APSDE-DATA.confirm: 0xE9 on task
08:50:25:892 ZCL attribute report 0xF0D1B800001A1F18 for cluster: 0x0300, ep: 0x01, frame control: 0x08, mfcode: 0x0000
08:50:32:436 Device TTL 2201 s flags: 0x7
08:50:33:271 ZCL attribute report 0x00178801021B226A for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
08:50:34:000 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:50:34:019 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:51:00:746 reuse dead link (dead link container size now 5)
08:51:13:385 Skip idle timer callback, too early: elapsed 912 msec
08:51:17:993 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:51:18:012 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
08:51:18:045 ZCL attribute report 0x7CB03EAA0A078E1F for cluster: 0x0300, ep: 0x03, frame control: 0x18, mfcode: 0x0000
