What’s up with my setup? I’m on 15, yet things are quite flaky. I know interference is also huge but I’ve tried lots of stuff along those lines; antenna location/orientation, wifi channels. etc.
Honestly, don’t care for those energy scans they’re proving to be more trouble than they’re worth and only a point in time reference AFAIK. We can’t say much from those. I’ve seen great perf from networks showing ‘busy’ and crappy perf from clean ones.
WAY more helpful is a description of your physical environment - what Wifi(2.4g) Channel you’re on how your stuff is hooked up. etc.
I’ve tried several permutations of wifi channels with my modem and router on channels 1,6 & 11. Doesn’t seem to make a difference at all. I’m using a conbee II coordinator on a USB extension cable. Things were working kinda ok until a recent HA update messed things up so badly I had to re-pair everything. I’ve tried re-pairing the flakiest ones again to no avail. The worst ones (Sengled bulbs) are very close to the coordinator, maybe 8ft and one wooden floor in between. LQIs are at or near 255 with a green line to the conbee in the visualizer. Just for grins I paired them to a routing switch in the same room and that was worse.
Perfect, so am I. What kind of machine runs HA, what kind of disk drive does it use (yes it matters)- what kind of port is it plugged into? (USB 2/3?)
at 8 ft. yeah prob some kind of interference but may not be external.
You said you’re on Zigbee 15, what Wifi2.4 are you on now (And because you bounced it around with no change I’m thinking that’s NOT it but we’ll check anyway)
How any devices have you got, and how many are routers? I don’t think Sengled bulbs are, so you would need a few other things nearby to give a good spread of possible connections. Again, I think green lines and LQIs are snapshots - they change all the time.
Sengleds ARE NOT routing devices. I use them SPECIFICALLY because they are not. I have at least one GE / Jasco Zigbee outlet (usually two) in each room and that forms the backbone of my mesh. On top of that a few sockets but mostly battery powered sensors beyond that. (I’m mostly Zwave - 84 devices on that mesh)
and I ignore the map in ZHA it’s notorious for being wrong. You dont even have basic connectivity lets get that first.
Just a few inches. You saw how drastic it was just moving the stick to the drive… I think that was about 6" maybe 10cm? It’s not much. Fortunately those hi frequencies fall off fast.
No. I have my ZWave Coordinator plugged into the same usb hub right next to my zigbee coordinator. I put a Bluetooth stick on the side port to give a few inches of separation but I’m not using it anymore since I started moving to esp32 Bluetooth proxies so it’s probably going to get yoinked.
If you worked yourself of @Hedda’s tips & tricks from top to bottom already you might be out of luck and your neighbors WiFi are winning the (airtime) “battle” against your ZigBee.
For me, my neighbors (wifi) won and I replaced all my ZigBee gear with esphome WiFi ones. Since then everything works a treat and in case it would start to get flawky in the future I have powerful debugging options (unlilke it was the case with ZigBee for me…)
