This looks promising, and the price is not too steep.
Is there a rubber seal on the inside of the lid (picture only show outside), or is it only the blue thing that is supposed to make it watertight?
### Problem description The Plant Monitor can be paired but doesn't show any enâŠtities It shows up as a TS0601 _TZE284_aao3yzhs Link: https://www.aliexpress.com/item/1005007330089764.html   ### Solution description Add a custom quirk to display Soil moisture and temperature ### Screenshots/Video <details><summary>Screenshots/Video</summary> [Paste/upload your media here] </details> ### Device signature <details><summary>Device signature</summary> ```json { "node_descriptor": { "logical_type": 2, "complex_descriptor_available": 0, "user_descriptor_available": 0, "reserved": 0, "aps_flags": 0, "frequency_band": 8, "mac_capability_flags": 128, "manufacturer_code": 4417, "maximum_buffer_size": 66, "maximum_incoming_transfer_size": 66, "server_mask": 10752, "maximum_outgoing_transfer_size": 66, "descriptor_capability_field": 0 }, "endpoints": { "1": { "profile_id": "0x0104", "device_type": "0x0051", "input_clusters": [ "0x0000", "0x0004", "0x0005", "0xed00", "0xef00" ], "output_clusters": [ "0x000a", "0x0019" ] } }, "manufacturer": "_TZE284_aao3yzhs", "model": "TS0601", "class": "zigpy.device.Device" } ``` </details> ### Diagnostic information <details><summary>Diagnostic information</summary> ```json { "home_assistant": { "installation_type": "Home Assistant OS", "version": "2024.8.2", "dev": false, "hassio": true, "virtualenv": false, "python_version": "3.12.4", "docker": true, "arch": "x86_64", "timezone": "Europe/Amsterdam", "os_name": "Linux", "os_version": "6.6.44-haos", "supervisor": "2024.08.0", "host_os": "Home Assistant OS 13.0", "docker_version": "26.1.4", "chassis": "vm", "run_as_root": true }, "custom_components": { "average": { "documentation": "https://github.com/Limych/ha-average", "version": "2.3.4", "requirements": [] }, "knmi": { "documentation": "https://github.com/golles/ha-knmi/blob/main/README.md", "version": "2.2.0", "requirements": [] }, "philips_airpurifier_coap": { "documentation": "https://github.com/kongo09/philips-airpurifier-coap", "version": "0.18.5", "requirements": [ "aioairctrl==0.2.5", "getmac==0.9.4" ] }, "hacs": { "documentation": "https://hacs.xyz/docs/configuration/start", "version": "1.34.0", "requirements": [ "aiogithubapi>=22.10.1" ] } }, "integration_manifest": { "domain": "zha", "name": "Zigbee Home Automation", "after_dependencies": [ "onboarding", "usb" ], "codeowners": [ "dmulcahey", "adminiuga", "puddly", "TheJulianJES" ], "config_flow": true, "dependencies": [ "file_upload" ], "documentation": "https://www.home-assistant.io/integrations/zha", "iot_class": "local_polling", "loggers": [ "aiosqlite", "bellows", "crccheck", "pure_pcapy3", "zhaquirks", "zigpy", "zigpy_deconz", "zigpy_xbee", "zigpy_zigate", "zigpy_znp", "zha", "universal_silabs_flasher" ], "requirements": [ "universal-silabs-flasher==0.0.22", "zha==0.0.31" ], "usb": [ { "vid": "10C4", "pid": "EA60", "description": "*2652*", "known_devices": [ "slae.sh cc2652rb stick" ] }, { "vid": "10C4", "pid": "EA60", "description": "*slzb-07*", "known_devices": [ "smlight slzb-07" ] }, { "vid": "1A86", "pid": "55D4", "description": "*sonoff*plus*", "known_devices": [ "sonoff zigbee dongle plus v2" ] }, { "vid": "10C4", "pid": "EA60", "description": "*sonoff*plus*", "known_devices": [ "sonoff zigbee dongle plus" ] }, { "vid": "10C4", "pid": "EA60", "description": "*tubeszb*", "known_devices": [ "TubesZB Coordinator" ] }, { "vid": "1A86", "pid": "7523", "description": "*tubeszb*", "known_devices": [ "TubesZB Coordinator" ] }, { "vid": "1A86", "pid": "7523", "description": "*zigstar*", "known_devices": [ "ZigStar Coordinators" ] }, { "vid": "1CF1", "pid": "0030", "description": "*conbee*", "known_devices": [ "Conbee II" ] }, { "vid": "0403", "pid": "6015", "description": "*conbee*", "known_devices": [ "Conbee III" ] }, { "vid": "10C4", "pid": "8A2A", "description": "*zigbee*", "known_devices": [ "Nortek HUSBZB-1" ] }, { "vid": "0403", "pid": "6015", "description": "*zigate*", "known_devices": [ "ZiGate+" ] }, { "vid": "10C4", "pid": "EA60", "description": "*zigate*", "known_devices": [ "ZiGate" ] }, { "vid": "10C4", "pid": "8B34", "description": "*bv 2010/10*", "known_devices": [ "Bitron Video AV2010/10" ] } ], "zeroconf": [ { "type": "_esphomelib._tcp.local.", "name": "tube*" }, { "type": "_zigate-zigbee-gateway._tcp.local.", "name": "*zigate*" }, { "type": "_zigstar_gw._tcp.local.", "name": "*zigstar*" }, { "type": "_uzg-01._tcp.local.", "name": "uzg-01*" }, { "type": "_slzb-06._tcp.local.", "name": "slzb-06*" }, { "type": "_xzg._tcp.local.", "name": "xzg*" }, { "type": "_czc._tcp.local.", "name": "czc*" } ], "is_built_in": true }, "setup_times": { "null": { "setup": 7.1326969191432e-05 }, "eccd7b20eecde60a7a4b75548536550c": { "wait_import_platforms": -0.016558641975279897, "wait_base_component": -0.0007912219734862447, "config_entry_setup": 12.98326518398244 } }, "data": { "ieee": "**REDACTED**", "nwk": 32106, "manufacturer": "_TZE284_aao3yzhs", "model": "TS0601", "name": "_TZE284_aao3yzhs TS0601", "quirk_applied": false, "quirk_class": "zigpy.device.Device", "quirk_id": null, "manufacturer_code": 4417, "power_source": "Battery or Unknown", "lqi": 100, "rssi": -75, "last_seen": "2024-08-19T13:34:24", "available": false, "device_type": "EndDevice", "signature": { "node_descriptor": { "logical_type": 2, "complex_descriptor_available": 0, "user_descriptor_available": 0, "reserved": 0, "aps_flags": 0, "frequency_band": 8, "mac_capability_flags": 128, "manufacturer_code": 4417, "maximum_buffer_size": 66, "maximum_incoming_transfer_size": 66, "server_mask": 10752, "maximum_outgoing_transfer_size": 66, "descriptor_capability_field": 0 }, "endpoints": { "1": { "profile_id": "0x0104", "device_type": "0x0051", "input_clusters": [ "0x0000", "0x0004", "0x0005", "0xed00", "0xef00" ], "output_clusters": [ "0x000a", "0x0019" ] } }, "manufacturer": "_TZE284_aao3yzhs", "model": "TS0601" }, "active_coordinator": false, "entities": [ { "entity_id": "update.tze284_aao3yzhs_ts0601_firmware", "name": "_TZE284_aao3yzhs TS0601" }, { "entity_id": "update.plant_monitor_1_firmware", "name": "_TZE284_aao3yzhs TS0601" } ], "neighbors": [], "routes": [], "endpoint_names": [ { "name": "SMART_PLUG" } ], "user_given_name": "Plant Monitor 1", "device_reg_id": "dd581646b6c8df6f29d816b4d4835118", "area_id": "bedroom", "cluster_details": { "1": { "device_type": { "name": "SMART_PLUG", "id": 81 }, "profile_id": 260, "in_clusters": { "0x0004": { "endpoint_attribute": "groups", "attributes": {}, "unsupported_attributes": {} }, "0x0005": { "endpoint_attribute": "scenes", "attributes": {}, "unsupported_attributes": {} }, "0xef00": { "endpoint_attribute": null, "attributes": {}, "unsupported_attributes": {} }, "0x0000": { "endpoint_attribute": "basic", "attributes": { "0x0004": { "attribute_name": "manufacturer", "value": "_TZE284_aao3yzhs" }, "0x0005": { "attribute_name": "model", "value": "TS0601" } }, "unsupported_attributes": {} }, "0xed00": { "endpoint_attribute": null, "attributes": {}, "unsupported_attributes": {} } }, "out_clusters": { "0x0019": { "endpoint_attribute": "ota", "attributes": { "0x0002": { "attribute_name": "current_file_version", "value": 77 } }, "unsupported_attributes": {} }, "0x000a": { "endpoint_attribute": "time", "attributes": {}, "unsupported_attributes": {} } } } } } } ``` </details> ### Logs <details><summary>Logs</summary> ```python [Paste the logs here] ``` </details> ### Custom quirk <details><summary>Custom quirk</summary> ```python [Paste your custom quirk here] ``` </details> ### Additional information _No response_
