Hi Everybody, I have use HA for a while and recently decided to move from deconz to ZHA to see if that would increase stability. Stability has improved, but I have one device which does not show up correctly in ZHA.
I would really appreciate if someone could explain which files (init.py, etc) to put where locally on my RPI such that I can use a local quirk for that device.
Yes custom quirks path directory with manually copied custom quirks work but are not need often unless got a rare odd device or a brand new device with specialized features or deviating from standard, see ZHA documentation and if possible help edit to improve those docs for other users:
Manually add and use a not yet merged custom ZHA quirk
If you have bought a non-standard Zigbee device that is not yet supported by ZHA but someone have written a ZHA "quirk" module (ZHA Device Handler/Zigbee Converter) that not get been merged into a "ZHA Device Handlers"" library release then you can add that manually as a custom ZHA quirk to your Home Assistant instance, (using something like File Editor or Samba share add-ons in Home Assistant).
Create a directory/folder for your custom quirks (for example /config/zha_quirks/)
Copy or create a quirk file in this directory (called it for example “devicemodelzyz_devicetypexyz.py”). This file should contain the Python script for the quirk and its specific Zigbee device signature unique to it.
Add configuration with the full path to the directory that now containing custom quirk module(s) that will override and take precedence over any built-in quirks matching any device that has the same Zigbee device signature. to Home Assistant's config.yaml
thanks for the explanation. I’ve done this for the “”“Samjin Multi 2019 Refresh Quirk.”"" because I wanted the tilt data (accelerometer x, y and z) which was availabe when I used Deconz / Phascon prior to switch to ZHA.
I added the quirk after pairing the device, and after restarting HA, I still don’t see the accelerometer sensor. Do I need to remove, and repair the device?
yes that’s exactly what I did. And I’m sure I have the appropriate quirk. Should the python files be in their own sub-direcory like it was when I downloaded the quirks zip file? I just moved them into the /custom_zha_quirks as per your advice.
In fact, if I look at the “Device info” panel for the device, it looks like its using the quirk. And when I click on the three dots menu, and choose “SmartThingsAccelCluster” I can read the x,y,z acceleration data in the zigbee message, its just not exposed as a sensor entity in home assistant.
Why are you expecting those values in entities and not as part of the event? Have you seen any instalation of this device & quirk where those values are assigned to individual entities?
By the way, don’t you have that info as attributes of your vibration sensor entity? I’m not saying I’m expecting this, just curious.
By the way, I have an Aqara vibration sensor connected thru ZHA and I don’t have any entity with X, Y and Z values.
Sorry I’m new to ZHA. I used to use the Deconz zigbee hub, and with the same multi-sensor device, there was a sensor entity that with a template, I could extrac the x, y, and z acceleration values. I’m not sure what you mean by getting the “values as part of the event”. Which event?
I don’t think there is a vibration sesnor entity. The “Workshop door” and “Accelerometer” are both binary sensors.
For your automations, you can have a trigger based on a event for this specific device, as described here.
And you can use the trigger’s variables to get information about those values on your event, as described here
You can go to Developer tools > Events and then start listening for zha_event, then move your sensor and you will have an event like this (this is a screens hot from my Aqara sensor’s event):
be aware that not all commands will provide the coordinates in the args, so maybe your automation will have to monitor for specific commands on events.
In this case, I probably will get the “X” coordinates under trigger.event.data.args.X or trigger.event.data.args.Y, etc…
Why don’t you share what you are trying to achieve with those values (X, Y and Z) or perhaps share your existing automation developed for DeCONZ so the community can try to help you more?
Binary sensors can also have attributes.
Take a look for this binary sensor (and perhaps any other entity within this device) under Developer tools > State and take a look for attributes. Maybe you have this info (X, Y, Z) there.
