Zigbee for plants exists?
Hi everyone, I’m looking for a sensor for plants (with light, humidity, etc’) that communicates via zigbee. All I find online is mi flora which is bluetooth (BLE) and ‘intermidiary’ esp32/esp12/arduino devices. I prefer not to use bluetooth at all if possible and to buy a zigbee device. Do you have any suggestions?
thanks
This device is Zigbee. I’ve never used it though.
https://spruceirrigation.com/sensors/
Just saw this thread and would like to ask if someone connected these linked sensors above into homeassistant?
I don’t see them on the supported list in https://www.zigbee2mqtt.io/information/supported_devices.html so would need some work to add https://www.zigbee2mqtt.io/how_tos/how_to_support_new_devices.html
There are a few issues with this sensor:
  • It doesn’t seal properly, so moisture gets into the case with the circuit board, which is not good
  • The temperature sensor is not reflected correctly in HA, so it is not useful for temperature
  • The moisture is not very accurate in HA.
It is too expensive for those drawbacks.
Could look at building your own. There is also a V3 that has the bill of materials that U can order assembled from jlcpcb.
I’ve now bought an ESP32 board which makes monitoring of ble sensors much easier.
