**Is your feature request related to a problem? Please describe.**
The solenoid…e walve SAS980WST-07 is successfully paired by ZHA but the devices are not all supported :
- On-Off swith OK
- Battery measurement NOK
- Consumption measurement NOK
**Describe the solution you'd like**
To have the battery and consumption measurement supported by ZHA
<details>
<summary>Device signature</summary>
```yaml
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0051",
"in_clusters": [
"0x0000",
"0x0001",
"0x0004",
"0x0005",
"0x0006",
"0x0702",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZE200_81isopgh",
"model": "TS0601",
"class": "zhaquirks.tuya.ts0601_valve.TuyaValve"
</details>
<details>
<summary>Diagnostic information</summary>
```yaml
"home_assistant": {
"installation_type": "Home Assistant Supervised",
"version": "2022.10.4",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Paris",
"os_name": "Linux",
"os_version": "5.10.0-12-amd64",
"supervisor": "2022.10.0",
"host_os": "Debian GNU/Linux 11 (bullseye)",
"docker_version": "20.10.14",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"myEnedis": {
"version": "1.5.1",
"requirements": [
"packaging>=20.8"
"hacs": {
"version": "1.28.2",
"requirements": [
"aiogithubapi>=22.2.4"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.2",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.82",
"zigpy-deconz==0.19.0",
"zigpy==0.51.3",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.2",
"zigpy-znp==0.9.1"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 22303,
"model": "TS0601",
"name": "_TZE200_81isopgh TS0601",
"quirk_applied": true,
"quirk_class": "zhaquirks.tuya.ts0601_valve.TuyaValve",
"manufacturer_code": 4098,
"power_source": "Battery or Unknown",
"lqi": 255,
"rssi": -52,
"last_seen": "2022-10-18T10:35:24",
"available": true,
"device_type": "EndDevice",
"signature": {
"endpoints": {
"1": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0001",
"0x0004",
"0x0005",
"0x0006",
"0x0702",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"active_coordinator": false,
"entities": [
"entity_id": "sensor.tze200_81isopgh_ts0601_battery",
"entity_id": "sensor.tze200_81isopgh_ts0601_smartenergymetering",
"entity_id": "sensor.tze200_81isopgh_ts0601_smartenergysummation",
"entity_id": "switch.tze200_81isopgh_ts0601_switch",
"neighbors": [],
"endpoint_names": [
"name": "SMART_PLUG"
"user_given_name": null,
"device_reg_id": "e3295d5e64929fda3e368f80ed9ef537",
"area_id": "zigbee",
"cluster_details": {
"1": {
"device_type": {
"name": "SMART_PLUG",
"id": 81
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0001": {
"attribute_name": "app_version",
"value": 72
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZE200_81isopgh"
"0x0005": {
"attribute_name": "model",
"value": "TS0601"
"unsupported_attributes": {}
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 0
"0x0702": {
"endpoint_attribute": "smartenergy_metering",
"attributes": {
"0x0000": {
"attribute_name": "current_summ_delivered",
"value": 0
"0x0300": {
"attribute_name": "unit_of_measure",
"value": 7
"0x0001": {
"endpoint_attribute": "power",
"attributes": {},
"0xef00": {
"endpoint_attribute": "tuya_manufacturer",
"attributes": {
"0xef00": {
"attribute_name": "mcu_version",
"value": "1.0.0"
"0xef01": {
"attribute_name": "time_left",
"value": 60
"0xef02": {
"attribute_name": "state",
"value": 2
"0xef03": {
"attribute_name": "last_valve_open_duration",
"value": 600
"0xef04": {
"attribute_name": "dp_6",
"value": 0
"out_clusters": {
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
</details>
<details>
<summary>Additional logs</summary>
Paste any additional debug logs here.
Don't remove the extra line breaks outside the ``` marks.
</details>
**Additional context**
Add any other context or screenshots about the feature request here.
