Zigbee Gateway ZXGWZ-04 Integration / Firmware
I purchased, on aliexpress, this Zigbee Gateway.
It has a Esp32 chip and a WRG1 chip.
It is powered by USB.
Does anyone know if there is a firmware that is not connected to cloud and works with HA ?
If it has the same ZigBee chip as the sonoff ZigBee bridge, maybe tasmota might work.
I also have this gateway.
Have you found a compatible firmware or is it to make it compatible with zigbee2mqtt for example?
Thank you!
IMG_20201128_094612|374x499
The Tuya WRG1 Module is not compatible with Tasmota.
Thanks you for your reply Paul.
