I recently installed the Hampton Bay Universal Wink Controller for my ceiling fan and I’ve been noticing some sporadic Unavailable connections from HA. I am on HA .105.3 and I am using the Nortek HUSBZB-1 controller for all my Z-Wave (10 devices) and Zigbee (1 bulb) for over a year now without issues. This fan controller is the first time I am actually seeing issues.
This is the setup in HA for this controller:
And at the moment if I try to turn the light off for example, I get an error and this message (debug enabled in HA for zigbee):
2020-02-12 20:07:09 DEBUG (MainThread) [bellows.ezsp] Send command sendUnicast: (<EmberOutgoingMessageType.OUTGOING_DIRECT: 0>, 0x453d, <EmberApsFrame profileId=260 clusterId=6 sourceEndpoint=1 destinationEndpoint=1 options=320 groupId=0 sequence=43>, 44, b'\x01+\x00')
2020-02-12 20:07:09 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'102b219c541750b658924a24ab1593499c650ba8ece5679cd17e'
2020-02-12 20:07:09 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'022ba19c546aff167e'
2020-02-12 20:07:09 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'8160597e'
2020-02-12 20:07:09 DEBUG (MainThread) [bellows.ezsp] Application frame 52 (sendUnicast) received: b'0040'
2020-02-12 20:07:12 DEBUG (MainThread) [bellows.ezsp] Send command nop: ()
2020-02-12 20:07:12 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'212821adbbcd7e'
2020-02-12 20:07:12 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'1328a1ad61d47e'
2020-02-12 20:07:12 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'82503a7e'
2020-02-12 20:07:12 DEBUG (MainThread) [bellows.ezsp] Application frame 5 (nop) received: b''
2020-02-12 20:07:13 DEBUG (bellows.thread_0) [bellows.uart] Data frame: b'2328b197541750b658924a24ab1593499c0e0bcded79817e'
2020-02-12 20:07:13 DEBUG (bellows.thread_0) [bellows.uart] Sending: b'83401b7e'
2020-02-12 20:07:13 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received: b'003d4504010600010140010000402c6600'
2020-02-12 20:07:13 DEBUG (MainThread) [bellows.zigbee.application] Received messageSentHandler frame with [<EmberOutgoingMessageType.OUTGOING_DIRECT: 0>, 17725, <EmberApsFrame profileId=260 clusterId=6 sourceEndpoint=1 destinationEndpoint=1 options=320 groupId=0 sequence=64>, 44, <EmberStatus.DELIVERY_FAILED: 102>, b'']
2020-02-12 20:07:13 DEBUG (MainThread) [zigpy.device] [0x453d] Delivery error for seq # 0x2b, on endpoint id 1 cluster 0x0006: message send failure
2020-02-12 20:07:13 DEBUG (MainThread) [homeassistant.components.zha.core.channels] [0x453d:1:0x0006]: command failed: off exception: [0x453d:1:0x0006]: Message send failure
2020-02-12 20:07:13 DEBUG (MainThread) [homeassistant.components.zha.entity] light.guest_bedroom_light: turned off: [0x453d:1:0x0006]: Message send failure
Any ideas? I even moved my Cree Zigbee bulb closer to the fan thinking it might have been a low signal from the controller but no difference. The bulb is noted as a Router and the fan is noted as an EndDevice.
Sorry if this is a duplicate, I couldn’t quite find specifics on these errors or my case really or maybe I couldn’t really find it.
