I am using the Conbee II stick plugged into a rPi4b running Home Assistant OS 5.13. Was working well/consistently but found since updating to 2021.6.x, my Zigbee devices show up as Unavailable at least half the time.
My Integrations page shows I am using:
Zigbee Home Automation
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191790-if00
Device info
and in the Zigbee Coordinator:
deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II
by ZHA
I do not have any references to zigbee in my configuration.yaml file
Here is the most recent log:
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:157
First occurred: 10:05:26 PM (1 occurrences)
Last logged: 10:05:26 PM
Error setting up entry /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191790-if00 for zha
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 293, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 102, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 157, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.8/site-packages/zigpy/application.py”, line 69, in new
await app.startup(auto_form)
File “/usr/local/lib/python3.8/site-packages/zigpy_deconz/zigbee/application.py”, line 80, in startup
await self.form_network()
File “/usr/local/lib/python3.8/site-packages/zigpy_deconz/zigbee/application.py”, line 151, in form_network
raise Exception(“Could not form network.”)
Exception: Could not form network.
Thanks for any help/advice!
