The visualisation is very deeply hidden and only visible to admin users - it would be useful to expose this element on the Overview dashboard and make it possible to display it elsewhere.
You can add it to the side bar with panel-redirect.
This could be a Documentation Request
I got it from somebody’s post. My configuration.yaml is:
frontend:
# Zigbee network map -----------------------------------------------------------
- name: panel-redirect
# url_path needs to be unique for each panel_custom config
url_path: redirect-zigbee
sidebar_title: Zigbee network
sidebar_icon: mdi:chart-bubble
module_url: /local/panel-redirect.js
# Where you want to redirect to
config:
target: config/zha/visualization
But it was a while ago - I can’t remember how it works…
Ah… It’s coming back to me now - it’s a custom thing. You also have to put a file called panel-redirect.js in your www folder. It should contain this:
Add a link to the sidebar to any path in Home Assistant
Put this file in <config>/www/panel-redirect.js
In configuration.yaml:
panel_custom:
url_path: redirect-server-controls
sidebar_title: Server Controls
sidebar_icon: mdi:server
config:
target: /config/server_control
class PanelRedirect extends HTMLElement {
connectedCallback() {
if (this._info) {
this._navigate();
set panel(info) {
this._info = info;
if (this.isConnected) {
this._navigate();
_navigate() {
history.replaceState(null, "", this._info.config.target);
const event = new Event("location-changed", {
bubbles: true,
composed: true,
event.detail = { replace: true };
this.dispatchEvent(event);
customElements.define("panel-redirect", PanelRedirect);
You can put a button in the toolbar for any of the system dashboards - I have several: automations, scripts, helpers, logs…
Edit: I’ve created a short community guide for anyone who’s interested, but it says pretty much the same thing as above.
The method below is much easier and no need for custom .js files:
panel_custom:
- name: zha_visualization
sidebar_title: "ZHA Visualizatoin"
js_url: /api/hassio/app/entrypoint.js
url_path: "config/zha/visualization"
embed_iframe: true
require_admin: true
config:
ingress: core_configurator
