Hi, I wanted to share a tutorial I made about how to flash Tasmota onto an ESP32 based Zigbee Hub with ethernet to make it compatible with ZHA just like the popular Sonoff Zigbee Hub.
https://thehelpfulidiot.com/a-wired-sonoff-zigbee-alternative
Thanks!
Hedda
(Hedda)
November 1, 2021, 3:19pm
2
FYI, more discussion and links about hacking this ZB-GW03 (and also it as a rebranded product) here:
https://community.home-assistant.io/t/zb-gw03-ewelink-ethernet-zigbee-gateway-now-hacked-with-tasmota-zbbridge-so-can-be-used-via-mqtt-or-as-a-remote-zigbee-adapter-with-home-assistant-zha/341223
ZB-GW03 eWeLink Ethernet Zigbee Gateway is a spiritual successor of the ITead Sonoff ZBBridge
It features an ESP32 chip and a wired Ethernet port (instead of the older ESP8266/ESP8285 and WiFi).
The Silicon Labs EFR32MG21 based Zigbee SiP radio module it uses is the exact same “SM-011 V1.0” modules and Zigbee firmware by CoolKit-Technologies that ITead Sonoff ZBBridge board uses.
The good news it that Tasmota community member cronyx has now hacked it with Tasmota ZBBridge firmware (using same…
PS: Now updated with links to the guides posted by thehelpfulidiot as well.
