i have a Zigbee Human Presence Sensor (WZ-M100-W) https://www.aliexpress.com/item/1005005200170242.html i can only make it work with Zigbee2MQTT Edge, but i get spamming always, so this make the whole HA work slow.
I see the same, probably because it is constantly checking the room and it not activating like a “normal” presence sensor.
But one thing I am struggling with is changing the values. It doesn’t matter if I try to change the values from Home Assistant or directly in the Zigbee2mqtt. It always revert back to the default settings.
