For the USB path what should i type? This is my config:
zwave:
usb_path: /dev/ttyUSB1
zha:
usb_path: /dev/ttyUSB2
database_path: /home/homeassistant/.homeassistant/zigbee.db
followed by my log output:
2017-11-03 16:09:23 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-11-03 16:09:26 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2017-11-03 16:09:36 WARNING (MainThread) [homeassistant.setup] Setup of zwave is taking over 10 seconds.
2017-11-03 16:09:37 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File "/usr/lib/python3.6/site-packages/openzwave/option.py", line 78, in __init__
raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't find device /dev/ttyUSB0 : ['NoneType: None\\n']"
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/zwave/__init__.py", line 269, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File "/usr/lib/python3.6/site-packages/openzwave/option.py", line 81, in __init__
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyUSB0 : [\'Traceback (most recent call last):\\n\', \' File "/usr/lib/python3.6/site-packages/openzwave/option.py", line 78, in __init__\\n raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \'openzwave.object.ZWaveException: "Zwave Generic Exception : Can\\\'t find device /dev/ttyUSB0 : [\\\'NoneType: None\\\\\\\\n\\\']"\\n\']'
2017-11-03 16:09:38 ERROR (MainThread) [homeassistant.setup] Error during setup of component zha
File "/usr/lib/python3.6/site-packages/serial/serialposix.py", line 244, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyUSB1'
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 191, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/zha/__init__.py", line 84, in async_setup
yield from ezsp_.connect(usb_path)
File "/usr/lib/python3.6/site-packages/bellows/ezsp.py", line 30, in connect
self._gw = yield from uart.connect(device, self)
File "/usr/lib/python3.6/site-packages/bellows/uart.py", line 266, in connect
xonxoff=True,
File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro
res = func(*args, **kw)
File "/usr/lib/python3.6/site-packages/serial_asyncio/__init__.py", line 410, in create_serial_connection
ser = serial.serial_for_url(*args, **kwargs)
File "/usr/lib/python3.6/site-packages/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/usr/lib/python3.6/site-packages/serial/serialposix.py", line 247, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyUSB1: [Errno 2] No such file or directory: '/dev/ttyUSB1'
2017-11-03 16:10:00 ERROR (MainThread) [aiohttp.access] Error in logging
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 500, in log
for key, value in fmt_info:
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 483, in <genexpr>
return ((key, method(args)) for key, method in self._methods)
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 436, in _format_a
peername = args[3].get_extra_info('peername')
File "/usr/lib/python3.6/asyncio/sslproto.py", line 306, in get_extra_info
return self._ssl_protocol._get_extra_info(name, default)
File "/usr/lib/python3.6/asyncio/sslproto.py", line 547, in _get_extra_info
return self._transport.get_extra_info(name, default)
AttributeError: 'NoneType' object has no attribute 'get_extra_info'
2017-11-03 16:23:24 ERROR (MainThread) [aiohttp.access] Error in logging
2017-11-03 16:23:38 ERROR (MainThread) [aiohttp.access] Error in logging
2017-11-03 16:24:42 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-11-03 16:24:43 WARNING (MainThread) [aiohttp.websocket] websocket connection is closing.
thanks!
