Zigbee in wall dimmer
Hi, there are enough in wall switches from a couple of good names that are not to expensive. But I can’t find any good dimmers.
There are some but I don’t know them and I don’t know if I would trust them in my wall.
I always liked the aqara lineup of devices but they have no dimmer modules.
Does anyone know of good in wall zigbee dimmer modules that that they have experience with and are of good build quality? If possible, not to expensive :wink:
What country? The available devices will vary. I use Namron in-wall dimmers, very happy with those.
Sorry, should have mentioned that. I am from the Netherlands.
Should have said that I am on Zigbee2MQTT. :slight_smile:
Thanks Nick. Ik will have a look at that document. But do you have any experience with any of them?
No, but I do have a couple of nue 3a switches and they have been good.
Hi, I’m using Zigbee led dimmer - Geschikt voor alle A-merken afdekmateriaal - SmartGateways.nl. Works very good.
Hi Rob,
Thanks, I saw those but I find them all relly expensive. They look good though and seem to be of high quality. That is why I mostly go for aqara. They are reasonably priced and have a good quality. Sadly they don’t have a dimmer as far as I know.
Is it also possible to dim up/down via zigbee/home assistant or only on/off via zigbee and then dimming via the physical knop?
I really liked Enbrighten Zigbee In-Wall Smart Dimmer but I am looking for something more inexpensive.
