Zigbee integration of Danfoss Icon2 Main Controller
I have just added one of our Danfoss Icon2 Main Controller to HA with Zigbee/ZHA.
It has identified most of the controls and sensors as expected, but some isn’t working as expected.
“HVAC Action” it can’t figure out how to handle, and the “Temperature”-sensor is a “little” lower than the actual temperature in the house. :slight_smile:
Could it be because the device isn’t identified correct? Danfoss Icon are some years old, but the “Icon2” is released last summer (to my knowledge).
Anyone having any idea how to solve this problem?
Br,
Anders
Submit a device support request to the ZHA Device Handlers (a.k.a. ZHA-quirks) repo if an issue for that device not already exist, see here → https://www.home-assistant.io/integrations/zha#how-to-add-support-for-new-and-unsupported-devices
Thank you for the link - didn’t notice that part of the ZHA ( might need to find some glasses… :smiley: )
Finally I got back to this issue.
I have now tried to do some debugging, and are now having some more log-entries.
What I’m missing is the state of the floor heating of it’s on or not.
It doesn’t seems like HA / ZHA can read the right info from the heating system.
I have found the following in the log:
2024-04-07 19:24:26.134 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame received incomingMessageHandler: [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=513, sourceEndpoint=4, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_RETRY|APS_OPTION_ENABLE_ROUTE_DISCOVERY: 320>, groupId=0, sequence=195), 148, -63, 0xf190, 255, 255, b'\x0cF\x12.\n\x10A0\x01']
2024-04-07 19:24:26.134 DEBUG (MainThread) [bellows.ezsp.protocol] Frame contains trailing data: b'\x02'
2024-04-07 19:24:26.134 DEBUG (MainThread) [bellows.zigbee.application] Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=513, sourceEndpoint=4, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_RETRY|APS_OPTION_ENABLE_ROUTE_DISCOVERY: 320>, groupId=0, sequence=195), 148, -63, 0xf190, 255, 255, b'\x0cF\x12.\n\x10A0\x01']
2024-04-07 19:24:26.134 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 4, 7, 19, 24, 26, 134386, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF190), src_ep=4, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=195, profile_id=260, cluster_id=513, data=Serialized[b'\x0cF\x12.\n\x10A0\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=148, rssi=-63)
2024-04-07 19:24:26.134 DEBUG (MainThread) [zigpy.zcl] [0xF190:4:0x0201] Received ZCL frame: b'\x0cF\x12.\n\x10A0\x01'
2024-04-07 19:24:26.135 DEBUG (MainThread) [zigpy.zcl] [0xF190:4:0x0201] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x0C>(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=True, direction=<Direction.Server_to_Client: 1>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True), manufacturer=4678, tsn=46, command_id=10, *direction=<Direction.Server_to_Client: 1>)
2024-04-07 19:24:26.135 DEBUG (MainThread) [zigpy.zcl] [0xF190:4:0x0201] Decoded ZCL frame: Thermostat:Report_Attributes(attribute_reports=[Attribute(attrid=0x4110, value=TypeValue(type=enum8, value=<enum8.undefined_0x01: 1>))])
2024-04-07 19:24:26.135 DEBUG (MainThread) [zigpy.zcl] [0xF190:4:0x0201] Received command 0x0A (TSN 46): Report_Attributes(attribute_reports=[Attribute(attrid=0x4110, value=TypeValue(type=enum8, value=<enum8.undefined_0x01: 1>))])
2024-04-07 19:24:26.135 DEBUG (MainThread) [zigpy.zcl] [0xF190:4:0x0201] Attribute report received: 0x4110=<enum8.undefined_0x01: 1>
2024-04-07 19:24:26.135 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xF190:4:0x0201]: Attribute report 'Thermostat'[16656] = enum8.undefined_0x01
2024-04-07 19:24:26.136 DEBUG (MainThread) [homeassistant.components.zha.entity] climate.danfoss_icon2_thermostat_4: Attribute '16656' = enum8.undefined_0x01 update
2024-04-07 19:24:26.137 DEBUG (MainThread) [zigpy.zcl] [0xF190:4:0x0201] Sending reply header: ZCLHeader(frame_control=FrameControl<0x10>(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 0>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True), tsn=46, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 0>)
2024-04-07 19:24:26.137 DEBUG (MainThread) [zigpy.zcl] [0xF190:4:0x0201] Sending reply: Default_Response(command_id=10, status=<Status.SUCCESS: 0>)
2024-04-07 19:24:26.137 DEBUG (MainThread) [bellows.zigbee.application] Sending packet ZigbeePacket(timestamp=datetime.datetime(2024, 4, 7, 19, 24, 26, 137527, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=4, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xF190), dst_ep=4, source_route=None, extended_timeout=False, tsn=46, profile_id=260, cluster_id=513, data=Serialized[b'\x10.\x0b\n\x00'], tx_options=<TransmitOptions.ACK: 1>, radius=0, non_member_radius=0, lqi=None, rssi=None)
2024-04-07 19:24:26.137 DEBUG (MainThread) [bellows.ezsp.protocol] Send command sendUnicast: (<EmberOutgoingMessageType.OUTGOING_DIRECT: 0>, 0xf190, EmberApsFrame(profileId=260, clusterId=513, sourceEndpoint=4, destinationEndpoint=4, options=<EmberApsOption.APS_OPTION_RETRY|APS_OPTION_ENABLE_ROUTE_DISCOVERY: 320>, groupId=0, sequence=46), 248, b'\x10.\x0b\n\x00')
Can anyone help me on from here. Should some quirking be done, or is there something there should be reported as “missing functionality”? I would of cause prefer to have it solved correctly, and also so other can make use of the solution, and not only me. I do expect other than me are using this product. :slight_smile:
I’ve just purchased and installed the Icon 2 system, and was able to link it to HA through Z2M. For the most part it works well. For each room I have in the Icon, I now have Climate Controls. I also have extra sensors that have been exposed. The only issue I’ve run into is that the only HVAC action is heat, while my icon is setup for cooling as well.
Hello. How did you manage to integrate the Icon2 Controller? I, indeed, successfully integrated I2 Controller into z2m (it appears on the z2m UI). However, when I try to create a frontend tile using the provided climate entities, it says “unknown”. Anyone has an idea what the problem is?
Gents, How did you add the controller, how do you get the controller into join mode for zigbee?
Regards, Fantic.
WWell I found a Github entry that was helpfull. The OK button on the Icon2 MC puts the controller into Zigbee joining mode. just FYI:
“On the Icon2 controller the right (OK) button works as a Zigbee pairing button.
If the left button is pressed so the light goes from Blinking-Steady-Blinking, the device is removed from network, so no factory reset needed. This needs to be done for endpoints to be updated (if sensors have been added after the ZB pairing).”
is anybody of you using ICON2 master unit together with one or more slave units?
Hello, I am considering Icon2 system for my house and would like to ask few questions of how it works with HA.
  1. Is it possible to use it in local mode only with zigbee integration without the need to connect it to internet?
  2. Is the integration working without major issues?
  3. Was anyone able to get the cooling mode working with HA
  4. Would you recommend this system as a whole?
Thank you
I’ve installed this very same Icon2 controller yesterday at my home.
It behaves exactly the same as it did for the author, apart from humidity sensors,
for me they’re showing hundreds of percents.
I assume the out of range temperature is suppose to represent optional floor temp sensors which aren’t present hence out-of-bounds readings.
@kongsted I’m interested in what kind of thermostat you’re using. Mine is 088U2125
And have you bought the Ally Gateway and had a better experience that way?
Hi everyone,
I’ve been running an ICON2 master for a while with 8 sensors (one per each room).
Using the Danfoss HACS integration it works flawlessly.
I also tried pairing it via Zigbee and it connects successfully.
However, here’s the issue.
My underfloor heating system (heat pump) has 2 circulation pumps:
  • one for the ground floor
  • one for the first floor
I control them separately with two Zigbee dry-contact switches.
The problem is that sometimes a sensor goes offline due to weak reception (with the official Danfoss system). When this happens, the “thermal actuator” opens and the circulation pump for that floor starts running, even if the target temperature has already been reached. I solved this behavior with an automation.
But this is only possible through the Danfoss HACS integration (not via Zigbee).
When I connect the ICON2 master over Zigbee, I can no longer see the “thermal actuator.”
:point_right: Is there any way to integrate it through Zigbee as well?
Thanks!
No answer?:disappointed:
Totally forgot this thread.
For my personal setup, I’ve changed from ZHA to Z2M. Must say it has a much wider support.
@manuel.garibaldi - not sure what actuator you’re having in your system? Is it actually a Zigbee enabled device, or what kind of device are you using?
How did you guys actually add the Icon2 MC into z2m? Nothing has worked for me so far, and it’s not exactly intuitive how to do it since there’s no documentation anywhere on it. Maybe I’m stupid but man is this annoying me. I specifically DIDN’T buy their gateway because i wanted the Zigbee connection directly.
Did you manage to figure this out? I’m about to buy one but would like to be sure everything works as expected with z2m.
I also cannot connect it in ZHA. I’m entering in pairing mode, ZHA says start interviewing but it gets stuck there. Anyone experienced this?
Hi guys maybe there is a problem when conecting with main unit version. Cause i wasnt able to connect in any way and only with a cable i recieved error that my main unit is decomissioned and needs to be changed.
