Every restart the Zigbee integration fails to restart - resulting in a long restart duration, missing automations.yaml and a pain to fix (always different every update).
- The log file states an error in config_entries.py.
Would appreciate some help/guidance.
Thks,
Bernard
PS:
- Using the ZBT-2 transmitter since late last year.
- I changed out the USB cable that came with the ZBT-2 two days ago. This is the first restart of HA after that change.
Here is the log:
Logger: homeassistant.config_entries
Source: config_entries.py:787
First occurred: 09:17:22 (1 occurrence)
Last logged: 09:17:22
Setup of config entry 'Home Assistant Connect ZBT-2' for zha integration cancelled
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 787, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 185, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/local/lib/python3.14/site-packages/zha/application/gateway.py", line 273, in async_initialize
await self._async_initialize()
File "/usr/local/lib/python3.14/site-packages/zha/application/gateway.py", line 256, in _async_initialize
await self.application_controller.startup(auto_form=True)
File "/usr/local/lib/python3.14/site-packages/zigpy/application.py", line 316, in startup
await self.connect()
File "/usr/local/lib/python3.14/site-packages/bellows/zigbee/application.py", line 188, in connect
await self._ezsp.connect(use_thread=self.config[CONF_USE_THREAD])
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/__init__.py", line 160, in connect
await self.startup_reset()
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/__init__.py", line 142, in startup_reset
await self._startup_reset()
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/__init__.py", line 134, in _startup_reset
await self.version()
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/__init__.py", line 187, in version
ver, stack_type, stack_version = await self._command(
"version", desiredProtocolVersion=self.ezsp_version
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/__init__.py", line 239, in _command
return await command(*args, **kwargs)
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/protocol.py", line 124, in command
await self._gw.send_data(data)
asyncio.exceptions.CancelledError: Global task timeout: Bootstrap stage 2 timeout
