Zigbee Intermittently "Failed to Setup"
I am using a Home Assistant Yellow (core 2024.1.5, OS 11.4). Zigbee (ZHA) works fine for a few hours but will give a “failed to setup” error after some random amount of time. If I restart HA it will work again for a while. I don’t see anything obvious in the logs below. Can anyone give me some troubleshooting tips? Zigbee had been working fine for a long time but over the last few weeks I’ve been having this problem.
Are you using the multiprotocol addon?
Here is what I did
Thanks so much for your reply. This is a real pain, I have been interested in trying out Thread. So strange, ZHA has been stable for months, one of the most consistent integrations I have but not lately. I don’t know if one of the updates broke it or what.
Hi, have the same problem here. Started giving errors recently after a update of HA. Only a reboot of the whole Yellow take it back online for a just day/days…
i’m having similar problem. zha works for a couple of days, them fails. The integration says Seup Fails, restarting. I never comes back. Only fixed with a HA restart, but sometimes even this does not work, and I need the boot the VM (proxmox) for ha.
I’m using a SkyConnect v1.0.
It becoming frustrating.
I did notice by VM said my memory was at 95% before my last reboot, do I need more memory ?(currently at 3G).
A brief “me too”. I’m running hassos on an x86 box. My zigbee coordinator is a SkyConnect. Two things that never recover this for me are:
  • unplug/replug the SkyConnect
  • restart Home Assistant
The only thing I have found to recover it is reboot the physical x86 box.
I haven’t yet tried the suggestions in this thread.
